New brake lathe turns the rotors on the vehicle.
Old May 5, 2011 | 07:37 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Default New brake lathe turns the rotors on the vehicle.
Have any of you other techs used the all new PFM9.2 DRO from pro cut . They are sweet , I had to go in to work early to get trained on how to use it . I testes for run out , and then matches the rotor and the hub which its mounted. All while attached to the vehicle .
Old May 5, 2011 | 08:24 PM
abig84's Avatar
that takes all the fun of beating the heck out of the rotor to get it off
Old May 5, 2011 | 08:36 PM
atvwarrior's Avatar
Yea sure does , kinda . I still had to take the rotors off and clean the mounting surfaces . And I thought we were just going to have to get a new rotor for the back , the old explorer just didn't want to give it up .
Old May 6, 2011 | 10:11 AM
DKSDAD's Avatar
On the car brake lathes are pretty cool, some manufacturers have required them for years (Honda since the '90s)
Old May 7, 2011 | 09:16 AM
ohsofly's Avatar
The garage I worked at for years had an on the car lathe, it was sweet. Kind of cumbersome, and takes just as long to set up as it did to just pull the rotors off and toss on the benchtop lathe. But it was handy for the one tons and the vehicles that you would have to remove the berrings to remove the rotors. Pop off rotors like out blazers have its kind of pointless, also our rotors are so cheap we can just get new ones for 30 bucks each.
Maxboost25psi
27
Mar 4, 2013 05:26 PM
ksunday1
Sep 26, 2012 10:10 PM
vze4yrte
Aug 30, 2010 09:08 PM
rooster
Jun 7, 2007 08:40 AM
blazerxtreme1
Suspension Tech
Jul 3, 2006 01:57 PM
