Notices
PC Q; BIOS Question...
Old Oct 8, 2016 | 06:36 PM
Schrade's Avatar
Schrade is on a distinguished road
Default PC Q; BIOS Question...
I got a dual boot machine - Windows and Linux - not really related to the problem tho'...
Neither OS will boot if I leave the wireless antenna for the mouse in it's USB Port - it will lock up after GRUB menu.
Pull the mouse antenna before I boot up, and all is fine.
So, I think a BIOS Setting is pulling up the USB Mouse antenna as a drive???
Anyone know what setting might change this action?
Old Oct 10, 2016 | 03:06 PM
richphotos's Avatar
That is an odd one. One thing I would check in the bios is the boot priority, set the USB to the last thing for anything to try to boot from,
do the hard drive, cd rom ect and have USB as the last option so it can load the OS first and once that is loaded then the mouse dongle?
That is all that I can think would be the issue.
Old Oct 14, 2016 | 05:56 PM
Schrade's Avatar
Thanks Rich - I failed to mention; the USB inTO which the mouse dongle is plugged (when it causes the problem), is a multi-USB hub added to the front panel, and which is connected to the mobo by a single connector:
As far as Boot Device Priority, I have 2 different hard drives as device 1, and 2; the third device is disabled, for booting (although SOME USB channel - not sure which one - either one of the 4 in the ONE device, or the single USB in the Multi-Port Device that's BELOW it).
I see no BIOS setting for 'emulation' of a USB channel, as a hard drive???
Attached Thumbnails PC Q; BIOS Question...-14706806_1157082657705668_4999289793696797537_o.jpg
Old Oct 14, 2016 | 06:16 PM
Have you tried disabling 'Legacy USB' support in the BIOS?
Does it act the same way with it plugged into the back of the machine directly into the motherboard USB ports? If so, you can get a USB extension cable to bring the dongle closer to the mouse.
Old Oct 15, 2016 | 11:27 AM
Schrade's Avatar
Haven't actually tried that yet Kyle; like to know what it is first, before blindly trying it (kind of like Plug N Pray diags on the Jimmy - replace parts hoping to find the problem).
I HAVE found that setting in BIOS. And on same page, the USB Device - 1 Hub, 4 'Drives'...
Will Legacy Disable make them be seen NOT as drives? (blowing up the OS GrubLoader is worse than an electrical short in the Jimmy, THAT'S a scary screw-up)
Attached Thumbnails PC Q; BIOS Question...-14589909_1157834754297125_1526687999662407620_o.jpg
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
