Wireless Bridges
Old Oct 15, 2010 | 10:01 PM
wlorton's Avatar
Default Wireless Bridges
In the other thread, there was mention of a wireless bridge, and just to inform everyone, I can let everyone know "wireless" options....
The first one is a wireless gaming adapter (which sometimes is expensive)
The second is a wireless bridge.
The third is a PLC adapter.
A wireless bridge is a secondary router that extends the wireless network and allows a downstreaming of information from the current wireless network to the devices connected to it.
An example would be to buy two Linksys Routers that are bridge compatible. Each manufacturer has a different slang for this, but any guy you talk to at best buy who is worth his salt should be able to assist. Now, one router is connected to the modem from your ISP (internet service provider), and the second router is connected to the device you wish to make wireless. Now some routers will require you to change the settings, and again these vary per manufacturer. I DO RECOMMEND you purchase the same brand bridge as router.
A PLC adapter is a newer idea, but much more expensive than the other two options. Basically the modem will plug into one PLC adapter that then plugs into an electrical outlet. A second PLC adapter is connected to your device that you want to make wireless and then a second outlet. One thing to note is that you need to have both PLC adapters on the same circuit, otherwise you will run into problems.
Ratings:
Ease of use (most to least)
Gaming adapter
Bridge
PLC adapter
Cost (least to most)
Bridge
Gaming Adapter
PLC adapter
Personally I recommend a wireless bridge as it will expand the current coverage of your network BUT if they are too close you will cause a slight interference and could slow the network, ie apartments dont need a second router...
Hopefully this clears up a bit....
Old Oct 16, 2010 | 04:23 AM
R2P's Avatar
R2P
R2P is on a distinguished road
The type of hardware depends on the need honestly.
If your current wireless setup doesn't reach far enough, get a repeater/range extender.
If you have two networks seperated by distance, use a wireless bridge.
PLC isn't even wireless so I'm not sure why the OP mentioned it. Basically it allows network communication over existing household power lines.
Gaming adapters are generally overpriced bridges. You'd be better off buying a wireless router with bridge capability and using that.
Old Oct 16, 2010 | 07:00 AM
wlorton's Avatar
Yes, but I am talking about "wireless", which you need to not run more wires, you are using existing.....
Old Oct 17, 2010 | 12:28 PM
Nemo1991's Avatar
Nemo1991 is on a distinguished road
thanks for puttin this up i might have to do this!
zball94
Feb 20, 2013 04:41 AM
trobbins
Dec 16, 2012 10:18 PM
Nemo1991
Oct 18, 2010 07:32 PM
felonyblazer96
Dec 4, 2007 10:04 PM
