Wireless Lights!!
Old Dec 4, 2007 | 05:35 PM
felonyblazer96's Avatar
Banned
felonyblazer96 is an unknown quantity at this point
Default Wireless Lights!!
i have another wonderfull question...i am making a custom light bar to put 5 aux lights on top and i was wondering if you can wire these ligths up with their original wires...i can get alot of off road lights but not with the wires......the wires are all cut off but there is enough wire to splice into them...can i just use some kind of wire??? please help
[/align]
Old Dec 4, 2007 | 06:09 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
Default RE: Wireless Lights!!
All you have to do is go to the store and get some wire and extend the wiring. I would probably use 12 or 14 guage.
Old Dec 4, 2007 | 06:45 PM
Banned
but where do i connect the wires 2?? what is eevrything i gotta buy so i can put a switch in my truck to turn them on/off as i like?
[/align]
Old Dec 4, 2007 | 07:07 PM
95_4door's Avatar
If you don't already have a switch that you will be using, all you have to buy is a toggle switch, an inline fuse holder, and more wiring.
Connect one of the leads on the toggle to the inline fuse holder, and then to the battery (or distribution block). Connect the other lead to the lights.
Old Dec 4, 2007 | 07:14 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Id put em on a "constant HOT" lead, run that wire to the toggle then run another wire to a inline or a fuseable link, THEN wire all the positive wires from the lights together and the same for the grounds run the ground to a barespot on the frame, secure the ground then put rustproofing over it. as for the hots just wire them together so you have 1 hot lead going to the switch.
Id get some 14g red and 14g black wire, some butt connectors,electical tape and bic lighter, a heavy duty 30a toggle switch and a idiot light. If you PM me I can get you a list of what you need, Infact ill check my garage for these things.. Ive rewired 3 cars in the past 4 years im sure I got some supplies collecting dust that ill send to you for the cost of shipping.
Old Dec 4, 2007 | 10:04 PM
WolfPack's Avatar
most offroad light companies sell a wiring harness you can buy for the lights. Gives you a branded switch for the cabin, a heavy duty relay, and plenty of wire to get from battery to lights. Any wiring harness will work though, since its essentially a relay, switch, fuse, and wiring like detroitmuscle was saying, but if you want pre-cut lengths, and fancy switchs and what not, just buy one. theyre like 20-40 bucks depending on the quality of the light theyre for
zball94
Feb 20, 2013 04:41 AM
trobbins
Dec 16, 2012 10:18 PM
edavison
Dec 20, 2010 09:55 PM
Nemo1991
Oct 18, 2010 07:32 PM
wlorton
Oct 17, 2010 12:28 PM
