5 speed effect on value?
Old May 1, 2025 | 08:39 PM
dadproject's Avatar
dadproject is on a distinguished road
Default 5 speed effect on value?
New member here. My daughter has a 2000 2dr Blazer with a 5 spd manual transmission. I know nothing about these, but I can't seem to find any others online. Everything I see has an automatic. Was the 5spd less common, and does having it make her car more desirable or worth more? Thanks!
Old May 2, 2025 | 12:29 PM
Thev5-speed was definitely less common. You didn't say if it was 2 or 4wd.
Since the automatics can eventually need a major service or rebuild that can cost thousands of dollars, it might be an advantage to have a manual in a 25 y.o. truck!
More broadly, the manuals will likely be more attractive to a niche customer base. Such a Blazer might be harder to sell in a smaller market compared to a larger metro area.
If nothing else, I congratulate your daughter for knowing how to drive a manual!
If I ever replace my 5-speed manual, 1982 Prelude I hope I can find another 2dr car with a manual as they are so much more fun to drive.
Old May 2, 2025 | 09:08 PM
AJBert's Avatar
If it is 4wd then it should have the steel front diff case, which is highly desired by those who offroad. As mentioned above, it would be desirable to a niche group. Many, many drivers don't have a clue how to drive with a manual tranny, so that does limit the folks that would want it. Particularly among anyone who started driving in the last 20 years or so.
Old May 3, 2025 | 11:56 PM
Ah, so the front diffs were different depending on the type of transmission. This is a good bit of knowledge!
Old May 4, 2025 | 03:29 PM
AJBert's Avatar
They were steel or cast iron, I forget which. Theoretically they should be stronger than the aluminum ones that are on all autos. Might be due to the manuals don't have a torque converter? I have no idea, though. I know all the 5 speed ZR's are that way, and I believe I heard the same with non-Z's.
Old May 5, 2025 | 05:16 PM
El_Beautor's Avatar
Welcome to the forum.
I agree with AJBert and Christine. The 5-speed trucks were definitely less common, but that will make them desirable to only a niche group. I doubt it would make them significantly more valuable.
ZR25speed
Dec 19, 2024 09:31 AM
fitrider150
Feb 3, 2010 09:56 AM
svd85
Nov 28, 2009 09:10 AM
noom14921992
Feb 28, 2009 02:54 PM
drperry
Apr 28, 2008 03:18 AM
