Battery cable replacement
Old Nov 1, 2022 | 01:47 PM
Stacy503's Avatar
Stacy503 is on a distinguished road
Default Battery cable replacement
I just bought a new cold start top post battery CCA 760 for my 2002 chevy blazer. Need to replace
negative battery cable. How do I start?
Old Nov 2, 2022 | 05:53 AM
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
Negative is easy, it's usually a short one that goes straight to the block but I am not familiar with specifics on these vehicles. I think that you can also buy an adapter from post to GM style but I am not sure about that. Call NAPA and ask them.
Old Nov 6, 2022 | 02:01 PM
Mods's Avatar
better off just getting a Side post with screw-term style battery, but if you must -
The Negative cable goes to the block, frame, and core support. the positive cable goes to the Alternator, MEGA-Fuse,and starter, go with #0 Copper stranded wire for all wires, and you will have to effectively makeup a custom cable as i dont think anyone makes conversion cables, alternatively find a top post to screw terminal/sidepost adapter. you will also need to source a fuseable link for the Alternator. sized for whatever output of Alternator you have.
Old Nov 8, 2022 | 08:37 AM
moosehauler05'blaz's Avatar
moosehauler05'blaz is on a distinguished road
You got the wrong battery if it is top post Take it back for a side post Why would you change your truck to fit your battery?
Outside of that You will need to change both posts This would be a good time to upgrade the wire gauge to something thicker for future extra uses
You will need 1/0Awg wire (welding cable is strong and cheap) A hammer lug And lugs that fit the gauge of the wire, A hammer, A youtube video on how to use a hammer lug Top post battery clamps And a youtube video on how to install them If you get a different battery may i recommend a 78 series duel posting (top And side) CCA 800 battery Which you will need to remove the rad cap off to squeeze in the battery ( Yes that close of a fit) This is for that extra cold cranking power in winter And a whole extra cell of reserved power. If you do not have the mechanical background skill of doing a battery swap 2 or 3 times before hand You will need someone that has to understand the smaller connected wires to Or from the battery that also need to transfer to the clamps
konfettix13
Mar 16, 2015 03:48 AM
Cessnaflyer
Dec 25, 2011 10:50 AM
jeanniec209
Jun 14, 2011 07:57 PM
mikejsansone
May 1, 2011 12:01 AM
Coryzblazer
Sep 17, 2007 10:49 PM
