Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
Going turbo-
Old Oct 25, 2006 | 05:39 PM
  #101
02 Vortech's Avatar
02 Vortech is an unknown quantity at this point
Default RE: Going turbo-
GOT DYNO'D @ 8psi
Most runs where @ the 245whp mark and i had to @ 255whp- @ 8psi-10.5:1 a/f ratio
255.5 whp @ 10.5:1 a/f ratio
327 Ft.lbs @
MODIFCATIONS OTHER THEN THE TURBO AND TURBO TUNE-
msd coil-
NGK TR6 plugs-
March underdrive pullies-
thats it----
its a dynodynamics dyno- he said that it dyno's 5% lower then a dynojet so hopefully next time i dyno which will be on a dynojet i will make around 270whp @ 340ft.bls- but thats later- im definatly happy with the results-
it lights up the tires from a 20punch- thing is i have to hold it in gear for the 1/2 shift- because it dumps to much fuel through the **** and it boggs like a mother- so when i hold it and let it stop spining it hits the 2nd gear shift spins another 10ft and is off like a rocket- its hard to launch definatly-
dyno/burnout video and pictures will be up in about an hour
Old Oct 25, 2006 | 06:04 PM
  #102
Awesome man! Good Job!
Old Oct 25, 2006 | 06:52 PM
  #103
02 Vortech's Avatar
Old Oct 25, 2006 | 09:19 PM
  #104
What's with the dip in the dyno sheet?
Old Oct 25, 2006 | 09:44 PM
  #105
02 Vortech's Avatar
ORIGINAL: swartlkk
its the shift-
Old Oct 25, 2006 | 09:52 PM
  #106
Hmm. Any dyno I've ever witnessed had the vehicle locked in 2nd... I can lock my truck or car in 2nd with my scan tool, so I'd imagine they'd be able to do it as well... You shouldn't have a shift in a dyno run...
Old Oct 25, 2006 | 11:01 PM
  #107
02 Vortech's Avatar
ORIGINAL: swartlkk
im sorry that "hole" is where the dyno guy hit the button when he let off the brake on the dyno.
here is the video-
http://youtube.com/watch?v=oDDjDnDdhtk
Old Oct 28, 2006 | 12:58 AM
  #108
02 Vortech's Avatar
I RAN IN THE 1/8TH MILE ITS OUR ONLY LOCAL TRACK-
8.8 @ 77mph-
1.96 60ft.- no spining just up and went-
THIS IS ON 8LBS OF BOOST AND 30" TALL TIRES (heavy as hell)
boost launch 8lbs- hammer it right before i let off the brake and right after the 3rd light turns on- and ended up with that- ran a 9.2 @ 76mph with a 2.3 60ft when i launched @ 4psi and bogged
Old Sep 24, 2009 | 11:22 PM
  #109
realestkilla420's Avatar
realestkilla420 is on a distinguished road
try to find manifolds from a syclone or a typhoon they were the gmc and chevy blazers with 4.3 and they were turbocharged i ebayed the manifolds around 800 for them
Old Sep 28, 2009 | 08:23 AM
  #110
UR50SLO's Avatar
UR50SLO is an unknown quantity at this point
What are you using for tuning? Should not be having boggs off the line or on a shift.
This is a 2dr 2wd?
What intake/injectors?
How much timing and AFR under WOT..
Sounds like the tune is what is keeping it from running decent. Should be making alot
more mph/et with that light of a truck.
~Scott
