90 S10 blazer 1 ton SAS.
Old 05-21-2017, 02:03 AM
Jstuck624's Avatar
Jstuck624 is on a distinguished road
Default 90 S10 blazer 1 ton SAS.
Hey guys anyone else out there with a similar build?
I started my build 2 weeks ago
if so can you share your builds with me.
Old 05-22-2017, 01:12 PM
abig84's Avatar
i got a 93 which is basically the same thing
if you have any questions me or a few of the other members who have done the swap can probably answer it
Old 05-22-2017, 01:19 PM
Jstuck624's Avatar
what axles did u use? I've got a Dana 60 front and a 14 bolt rear. I ask because I'm debating on tire size leaning towards 38-40 range. Worried about pumpkin clearance.
Old 05-23-2017, 12:12 PM
abig84's Avatar
im just running half tons (gm 10 bolts out of a k5 blazer) and 33 14.00 inch tires. i contemplating running 1 tons when i built it but with those small of tires i figured they would be getting hung up all over the trails.
i would guess i have 9 inches of lift and the front tires might barely rub in extreme flex circumstances
Old 05-24-2017, 01:02 AM
Jstuck624's Avatar
yea I'm thinking I'll need to run 40s to clear. I'll probably end up cutting fenders as well
Old 05-25-2017, 03:45 PM
Jstuck624's Avatar
Default Will 15 in rims fit on gm 14 bolt rear drums?
Title says it all. Will 15" rims clear the rear drums on a gm14 bolt 1 ton rear axle?
Old 05-25-2017, 05:47 PM
rexmburns's Avatar
Super Moderator
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Depends on the back spacing. You will need a lot of offset. If are you planning to run a 60 for a front axle that is going to limit you more than the rear will.
Edit I also merged your threads as well as moved it to the appropriate sub forum for you. Rather than starting a bunch of new threads regarding your build just post your questions in this one so that way people can know the history.
Old 05-27-2017, 08:22 AM
abig84's Avatar
mine did with 3.5 inches of backspacing on my k30. front dana 60 they will not without some caliper grinding.
so those are 15x10 rims with 3.5 backspacing. they were close to the drum in the back but they fit without any rubbing. i eventually did a disc brake swap in the back
kinda hard to see but you can see the drums sticking out with the same rims in this picture taking by a potato
thewickedk5
10-22-2011 12:18 PM
Doggpool
05-26-2011 04:49 PM
bclhaezveyr
02-08-2011 04:48 PM
rastoma
12-29-2009 04:18 PM
Security
05-25-2007 04:26 AM
Quick Reply: 90 S10 blazer 1 ton SAS.
