Leveling kit?
Old Jan 5, 2008 | 10:42 PM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: Leveling kit?
2"
Old Jan 5, 2008 | 11:16 PM
WolfPack's Avatar
If you really want to lift the front end, without doing the suspension lift, and without cranking tbars, get actual aftermarket torsion bars. Sway-away makes t-bars for our trucks that run $450. It in effect is like putting in a taller, stiffer spring. It will give you the lift like a tbar crank, but you wont have sag or spring rate deterioration over time like you will with a simple crank.
Best bet would be the lift with the new control arms and then get new t-bars...but then again for that price you could probably just get the 5-6' suspension lifts..
Old Jan 5, 2008 | 11:27 PM
mdehoogh's Avatar
regardless of how you lift it, with the exception of the big 5"/6"++ kits, the diff stays stationary and the wheels move further away from the diff. a steeper CV shaft angle is what makes up the difference. the steep angle is what will kill your front end in the long run.
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
Tinted
Lifting Tech
Jan 16, 2011 12:39 PM
grensha2
Suspension Tech
Dec 23, 2010 04:24 PM
robert25119
Jan 5, 2010 01:35 AM
Jfutch101
Lifting Tech
50
Jul 22, 2009 04:48 PM
