Lift Suggestions
Old Feb 23, 2009 | 02:25 PM
  #21
Default RE: Lift Suggestions
Please be aware that lifting the back with a SOA swap and not doing something more radical than a t-bar crank on the front will result in a staggered look with the back end being 2-2.5" higher than the front. This will not make for an ideal ride...
Old Feb 23, 2009 | 02:26 PM
  #22
drperry's Avatar
You'll have to get drop brackets for the entire front suspension, pretty much... Might as well save up for a 6" lift and go that way...
No amount of t-bar cranking can make it match the SOA job.
Not to mention, with your t-bars cranked that much, you'll wear out your front end like no tomorrow, and ride like a lumber wagon
Even just levelling the front end to a stock height rear end is cutting it close...
Old Feb 25, 2009 | 01:34 PM
  #23
Byte Stryke's Avatar
Byte Stryke is an unknown quantity at this point
to get a 31 under the front end of an LS you are going to need ~5 inches of lift and some trimming depending on your offset.
I went with a 2 and 2 with 4inch offset and I Rub on the outside now. (The insides are now safe though!)
I am trimming it this weekend.
Old Feb 25, 2009 | 09:14 PM
  #24
RedneckS10's Avatar
RedneckS10 is an unknown quantity at this point
hey anybody know what would be a good lift for a 1997 blazer s104 door LT? and how much it would cost?? thanks guys! -Nick
redhotxoxo96
Suspension Tech
Jan 14, 2014 06:49 PM
95blazerlt
Sep 1, 2013 10:30 PM
ultrapipe
Lifting Tech
Oct 16, 2012 12:19 PM
clw97bravada
Lifting Tech
Oct 13, 2010 05:01 PM
18koalabear
Jul 2, 2005 11:29 PM
