Noob to winching with questions
Old Apr 25, 2014 | 02:39 PM
uhlhazard's Avatar
uhlhazard is on a distinguished road
Default Noob to winching with questions
Hey guys, I just installed a winch to my truck and have a few questions.
Build thread:
UHLCLAN • Login
My tree saver just has loops on each end. Am I supposed to use a shackle to connect the tree saver to the ****** block?
I was shopping for a tree saver that had hooks on each end that could just connect straight to the shackle but they seem to be pretty uncommon.
p.s. anyone know of some good ORV parks in or around San Antonio or Houston?
Old Apr 25, 2014 | 03:24 PM
rexmburns's Avatar
Super Moderator
Yes you will want to get yourself a few good d-ring shackles if you plan to do some winching. They can be used in many ways and are much safer than a standard hook.
Edit: I just looked at your build thread and noticed you are installing a hawse fairlead. Do you intend to install synthetic rope? I wouldn't run the hawse with a cable. It will put additional stress on the cable and it will also make your winch pull much harder at any angle other than straight on due to the friction it will cause. I'm not saying it can't be done or that others haven't but I wouldn't personal do it!
Old Apr 25, 2014 | 04:08 PM
uhlhazard's Avatar
I'm trying to conceal the install. I won't do the rollers, they just invite eyes on my car. I have some rediculous drings and will make sure to use them.
The problem with synthetic is that it is hot in south texas, it is hot in my engine bay and my winch brake is inside the drum. They would break down really fast. My brother has a similar install and nuked his synthetic rope in 10 or so pulls.
Definitely safe when it breaks though!
Looking at some tree straps at (30000lbs) but the WLL is only 10500. If I use my 18K ****** block against myself/tree I have the capacity to destroy the tree straps given a 16k load capacity.
Where do they sell tree straps with a wll of 16k?
Old Apr 25, 2014 | 04:48 PM
rexmburns's Avatar
Super Moderator
If concealment is a concern you could use something like this and hide a roller really well where your winch is mounted. Quadratec Roller Fairlead License Plate Mount | Jeep Parts and Accessories | Quadratec. As for tree straps I don't have a clue I've always used my tow strap as a tree strap! I like it cause it gives me extra reach when a tree isn't so close.
Old Apr 25, 2014 | 04:54 PM
uhlhazard's Avatar
That is a good idea!
I just went outside and I'd have to some major cutting to my bumper to stuff in the roller. I figure if the hawse wears out I'll grab another one and some more wire rope. That stuff is getting cheap with synthetic everywhere now.
Did you run a fuse on your winch? I seem to be in the minority on this idea lol!
Old Apr 25, 2014 | 05:12 PM
rexmburns's Avatar
Super Moderator
Justake sure you are checking your winch line after every putting that you pull with it and try to pull as straight as possible and you should be ok for a bit. I'm not sure how you would run a fuse on a winch? It's wired direct to the battery and the draw would almost certainly pop a fuse instantly.
Old Apr 25, 2014 | 05:34 PM
uhlhazard's Avatar
I got one of these: Mega Fuse Holder Fuse Block with 450 Amp Mega Fuse Included | eBay
Winch is rated to pull 430 amps maximum. I'm worried about inrush current now so I may have to suck it up and route the wiring with love and keep an eye on it like the starter wire.
SirBlazeAlot
Tires and Wheels
Jan 25, 2011 08:51 AM
elchicano
Tires and Wheels
16
Jul 8, 2010 05:48 PM
JShark
Oct 28, 2009 08:21 PM
Streetskater27
Performance & Brainstorming
May 22, 2009 02:32 PM
vankuen
Sep 22, 2007 05:26 PM
