What can I do to my 2wd to handle offroading better?
Old 05-05-2009, 10:38 PM
fortmyerspolice's Avatar
fortmyerspolice is an unknown quantity at this point
Default What can I do to my 2wd to handle offroading better?
I daily drive it but sometimes I go on trails with it through rocky hills and sugarsand. I know I should of gotten a 4wd but it's too late now. What can I do to make it a little more useful in getting through tough spots of excessive sugarsand? I got stuck once in sugarsand, which is why I'm making this post.
BTW it's an 01 blazer with 80000 miles on it.
Old 05-05-2009, 11:21 PM
GMJimmy's Avatar
GMJimmy is on a distinguished road
Your tires will make a significant difference, and if sand is your main concern, then you can still get a good set of daily drivers that will perform well for the stuff you want to do.
http://www.stripersonline.com/surfta...d.php?t=488616
Best of luck
Old 05-06-2009, 01:24 AM
boomtruck97's Avatar
boomtruck97 is an unknown quantity at this point
add in a phantom grip locker in your rear diff, its basically 2 plates with a set of hardcore springs in the middle that turns ur 2wd open diff into a Limited Slip diff - in other words, 2 tires will power you and spin versus the current one wheel wonder you have.
or if your cheap just weld the diff - that works but i dont personally recomend that.
Old 05-06-2009, 06:55 AM
x2 on both accounts. Tires and getting the power to all driven wheels will maximize the potential of your truck.
A phantom grip (if even available for the 7.625" rear end) may work well for sand, but if screwing around on rocks where one wheel may have a ton more traction than the other, you will want an actual locker. A drop in "lunch box" locker will definitively lock both your wheels together, but they do have downsides.
Old 05-06-2009, 07:06 AM
Thanks guys. I don't see anything on the phantom grip website for a 10 bolt. Anyone have any other suggestions?
Old 05-06-2009, 07:20 AM
Check out SummitRacing.com for the lunch box style locker by Powertrax.
Old 05-06-2009, 04:54 PM
What are the downsides of using the powertrax locker besides screeching tires on every turn
Old 05-06-2009, 05:04 PM
oisinirish's Avatar
I thought the powertrax locker released during normal driving?
Old 05-06-2009, 06:11 PM
Not necessarily releasing during normal driving, but rather unlocking when not under power. I have used them in the past and they were a bit different to get used to. By far the best way to turn is while coasting. They may have improved over the years though.
Old 05-06-2009, 09:40 PM
blazen99's Avatar
blazen99 is on a distinguished road
i heard u can pressure ur E brake down a few clicks till it gets enough pressure and locks in your non drive wheel in
Quick Reply: What can I do to my 2wd to handle offroading better?
