What can I do to my 2wd to handle offroading better?
Old 05-06-2009, 10:06 PM
BlazerGlenn's Avatar
BlazerGlenn is on a distinguished road
i know the best thing to do sell it and buy a 4wd blazer.
Old 05-06-2009, 11:21 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if you would of taken the to the OP's first statement you would of seen that getting a new blazer is not an option, perhaps next time youll take the time to read the entire thread and make a meaningful suggestion.
Old 05-07-2009, 10:20 AM
AllEiz0nMe's Avatar
AllEiz0nMe is on a distinguished road
Originally Posted by fortmyerspolice
What are the downsides of using the powertrax locker besides screeching tires on every turn
We have a detroit ez locker in ours (same as powertrax) the only time it screeches around corners is when my hubby is driving like a dummy. I've had no problems at all when I drive it. But then again I don't drive like a maniac like he does! lol
Old 05-07-2009, 10:11 PM
blaz's Avatar
blaz is on a distinguished road
First check your glove box and make sure it doesn't have the G80 RPO code. If it does just get some tires because the G80 will work fine for light wheeling. If it doesn't have the G80 then reserch all lockers before making a decision. Lunch box lockers are cheap and effective, but if you drive on ice you will fishtail LOTS. You can pick up a whole rear end with a G80 and this will also lit you select from various gear ratios that will allow for larger tires if you want. These are just afew of the many options. All I can say is read, read then read some more on all the S10 spacific sites (if you need some links let us know).
Old 05-19-2009, 12:18 PM
muddigger01's Avatar
muddigger01 is on a distinguished road
sounds like some one needs a straight axle swap
Old 05-19-2009, 01:07 PM
WolfPack's Avatar
that would solve the 2wd-sanding issues
Old 05-29-2009, 08:50 AM
amazinnblazin's Avatar
amazinnblazin is an unknown quantity at this point
a few suggestions...
1. trade it it for a 4wd!
2. drive faster!
3. Just kidding, someone else prolly has a few ideas though!
/ \ 4wd4L
Old 05-30-2009, 12:20 AM
Blue Blazer is an unknown quantity at this point
if u are in sand alot, just lower ur tire pressure, and that helps alot
chris015
Engine & Internal
07-25-2011 09:13 PM
Eff10
04-01-2011 03:19 AM
callmedave
12-06-2010 02:31 PM
Hanr3
01-22-2007 09:27 AM
02 Vortech
Engine & Internal
06-29-2005 06:12 AM
Quick Reply: What can I do to my 2wd to handle offroading better?
