Winch question
Old Jan 4, 2011 | 08:49 PM
scanlojs's Avatar
scanlojs is on a distinguished road
Default Winch question
Whats the minimum rated weight of a winch I'd want to put on my Jimmy?
Old Jan 4, 2011 | 09:07 PM
Logan's Avatar
Logan is on a distinguished road
8500lbs
Old Jan 4, 2011 | 10:00 PM
AJBert's Avatar
I'd go 9K to be sure, but I run with an 8K presently. I can turn it into a 16K using my block so I'm not too worried, other than pulling my frame out from under the body...lol
Old Jan 5, 2011 | 01:00 AM
old skool luvr's Avatar
you do know you're not supposed to anchor the other end of the truck with a strap, right?
Old Jan 6, 2011 | 03:05 PM
AJBert's Avatar
That's how I straighten out the frame now and then...lol
Old Jan 6, 2011 | 03:23 PM
BigBlockBlazer's Avatar
BigBlockBlazer is on a distinguished road
The standard is usually twice the weight of the vehicle.
4000 lb truck = 8000 lb winch
Old Jan 7, 2011 | 10:39 AM
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
8k winch will be fine. Buy a good ****** block and use it whenever the situation allows, that will put way less stress on the winch . Ive never weighed my rig , but I ballpark it at around 6-6500lbs. Ive never had anything but an 8k Warn and the winch has never failed to pull the truck.
Old Jan 7, 2011 | 10:43 AM
Why would you put your weight at 6500 lbs? From the factory they are 4100, I run Rocks-44's-468 BB and it's just over 6000.
Old Jan 7, 2011 | 01:23 PM
Its just a ball park. Rockwells are 300Lbs (or something like that) heavier than 1 tons once they are stripped. That being said, my buddy just weighed his rig at the scales and it was 7500lbs. He has a toyota 4 runner with a SBC, rocks, and doubler. Im on tons, sbc, and a 203/lomax doubler. Ive put 3 xtra x members on it, and 14 sticks of HREW for the cage, sliders,bumpers. All of my tow points are 1/2" thick plate. Im basically just guessing, but with my frame/cage ect being built like a brick ****house , I would think im pretty close.
Edit- you are correct with the factory weight though- http://coloradok5.com/specs.shtml
newguy
Jan 4, 2014 05:26 AM
NVANZEE
Jan 7, 2010 11:57 PM
amazinnblazin
Oct 13, 2008 06:30 PM
akcalvin
Sep 22, 2008 10:34 AM
Tippman7641
Dec 15, 2007 11:11 PM
