2001 A-pillar...
Old Jan 6, 2009 | 05:03 AM
RockingRobin69's Avatar
RockingRobin69 is an unknown quantity at this point
Default 2001 A-pillar...
New member here & also to to the Blazer. Need to know what is behind the A pillar on the drivers side as I have to drill a very large hole. Wiring? Cables? Thanks.
Robin...
Bumping to the top with a new title in hope for some responses.
Old Jan 10, 2009 | 02:29 AM
Cyron's Avatar
Cyron is an unknown quantity at this point
Default RE: 2001 A-pillar...
not sure whats behind a 2001 i have a 97, but you can just grab the a pillar and pull it towards you away from the body and it just unclips
Old Jan 19, 2009 | 08:53 PM
Pull off the a-pillar to do any modification such as this. It is just held on by spring clips.
Old Jan 19, 2009 | 09:04 PM
Pullin it off is no problem. My concern is whats behind there. Is it a route for wires running up to the OHC? Will I encounter wiring as I drill through the A-pillar? Thanks.
Robin...
Old Jan 19, 2009 | 09:33 PM
Wait, you want to drill into the A-pillar itself and not just the trim? There is wiring there, but it is surface mounted. I would strongly advise against drilling into the A-pillar. If you want to mount gauges, get an appropriately molded a-pillar with gauge pods.
Old Jan 20, 2009 | 03:23 AM
Kyle, I need to drill through the A-pillar. I'm installinga spotlight. Like the police use. I have done this before on other vehicles but this is my first Blazer. The install requires drilling through the A-pillar using a 1/2 drill bit so thats why I'm asking about whats in there. The inside trim panel needs to remain in place so the hole being drilled is one straight shot into the interior. I can't step-drill it either.Thanks.
Robin...
Old Jan 20, 2009 | 06:36 AM
I believe the wiring should be up towards the windshield which you should be fairly far away from with your drill. You can still remove the a-pillar to note where everything is (and should) prior to drilling anything. You are going to have some fun with the door as it covers quite a bit of the a-pillar.
Reason I say not to drill the a-pillar is due to the chance of roll-over with pretty much any SUV. Drilling through the a-pillar can cause it to collapse and not protect you.
Old Jan 20, 2009 | 07:55 AM
Thanks Kyle. Thats pretty much whatI needed to know. Thanks again.
Robin...
ryankinder82
Feb 24, 2010 02:12 PM
Bigringtravis
Detailing
Mar 4, 2009 03:58 PM
Ugly_Monkey
Feb 15, 2009 09:56 PM
getonerd
Apr 8, 2008 06:39 AM
Johnkoch
Jan 6, 2008 03:46 PM
