2nd Generation Underbody
Old Aug 14, 2009 | 02:19 AM
wlorton's Avatar
Default 2nd Generation Underbody
So looking through various posts using the search function....
I can see some rust on my frame... just surface rust.. but I want to get rid of it... So what should I do??
My thoughts were to get some jack stands... take a weekend and sand it down... spray some rust stopping paint and then cover that with a coat of flat black paint...
What should I mask and what should I remove?
Also I might be replacing the brakes so I will probably paint the calipers too....
I saw the first gen underbody paint job... looked amazing but didnt address the rust issue...
Old Aug 14, 2009 | 07:39 AM
oktain's Avatar
Surface rust can usually be sanded, as long as it isn't rotted through. I'm probably going to do the same thing sometime before school starts... it's an eye sore from far.
Old Aug 15, 2009 | 01:47 AM
wlorton's Avatar
So looks like the last weekend in august I might go pick up about 10 cans of rustoleum flat black... and some new rotors and brake pads... and maybe just go ahead and flush all the fluids... woot woot... Looking up guides and tips how to paint the underbody... can I just paint it all?
Old Aug 16, 2009 | 12:48 AM
bowtie lifer's Avatar
bowtie lifer is on a distinguished road
The key to not wasting your money is adequate prep work. Degrease, wire brush, solvent wash, and a rubberized undercoat would be far better than rustoleum...
Old Aug 16, 2009 | 01:22 AM
wlorton's Avatar
Now thats where a dilemma pops up... I have seen paint versus rubberized coating... paint = cheaper... check when cleaning.. and simply re apply.... undercoating has to be painstakenly applied or you cover essential nuts and bolts and ruin things.... atleast it was in another article I was reading...
Old Aug 20, 2009 | 05:54 AM
Not sure that I understand the "ruin things" part but unless you prep extremly well the etch prime everything the rustoleum is less than a chip away from flaking off. With any "rattle can" application a bit of care is called for as to not get it where you dont want it. What type of material is applied by your dealer or factory when ordered on a new vehicle? Just my opinion though, been painting cars for 20 some years now. Best of luck with the project.
Mag-300
Feb 17, 2012 08:56 PM
gatorboy44
Nov 14, 2011 11:06 PM
blazinloud
Feb 1, 2007 11:22 AM
2001blazer
Mar 15, 2006 03:01 PM
