Another Hinge thread
Hi All,
A while back my hinge pin bushings must have failed. I never noticed it but then around Christmas the door got stuck and I forced it closed and pushed the spring out and bent the pin that holds the spring on the bottom of the hinge.
Obviously I need new hinge pins and bushings but I also need the pin that goes on the body side of the hinge with the little wheel that the spring bar? Rotates on.
I have the spring and two new hinge pins and I'm going to order the oversized bushings (thanks to this place I found them) but I'm not sure if I'm screwed with the the other pin being bent.
Here's a pic of my upper drivers side hinge:
It's hard to see in the pic but the bottom of right pin is bent towards the front of the truck. Do I need to get all new hinges now or is there a place to get that other pin? Or do I have to buy a whole hinge assembly to get that piece?
Thanks!
-John
Thanks!
-John
Found the piece on the total automotive site. Figured I'd post it here in case anyone runs into the same issue:
Catalog :: Total Automotive Hinge Kit Solutions
Part number: TAI - GMRP04
Weedenski
30
06-03-2009 10:57 PM
02 Vortech
Nitrous, Super Chargers, & Turbos
10-13-2008 07:38 PM
