Clear corners with fog lamps?
Old Aug 11, 2009 | 07:29 AM
oktain's Avatar
The corner lights and fog lights are mounted to the grille, you'll see under the chrome strip there's two cut outs you can grab a hold of, same with the part under the hood latch if you tug firmly the grille will pop off.
I'd suggest putting masking tape and rags on your bumper as I scratched mine up pretty badly when I pulled my grille off.
You should be able to get a look at the fog light then. The only thing I can think of is buying cheap eBay clear corners and modifying them somehow... the biggest problem I can see with that though is breaking the seal and getting moisture in your lights.
I thought I had seen a set made to go with fog lights... hmmm.
*Edit* if you wanna pay 77 bucks, http://cgi.ebay.ca/98-99-00-01-02-04...d=p3286.c0.m14. They look like you have a plug you can pull to put your fog lights in... I may be wrong though, I'd ask the seller.
Old Aug 11, 2009 | 10:15 AM
wlorton's Avatar
Thanks.... I was hoping for something a little different... but I might have to settle...
Old Aug 11, 2009 | 10:20 AM
oktain's Avatar
That was an example I found after 5-ish minutes of searching. Keep looking, The only thing you may find are corner lights with the fog-light built in. Like that one had the plug in the fog-light housing which made me think you'd be able to install it.
Old Aug 11, 2009 | 10:25 AM
wlorton's Avatar
I didnt find anything like that... I searched google... ebay... craigslist... for probably a good hour
I didnt mean to sound like they sucked... just that i thought you could buy just the turn signal... and leave the fog light be.... but if thats the only option...
Old Aug 11, 2009 | 12:33 PM
oktain's Avatar
It would seem so, unless you want to risk ruining a clear corner by butchering it to gain that fog-light function.
Old Aug 11, 2009 | 09:35 PM
wlorton's Avatar
I did see a thing on baking the light until the sealer comes loose and then removing the amber.... but IDK if that was for turn signals or for the older style blok headlights amber corners...
Old Aug 11, 2009 | 09:41 PM
JST4SHO's Avatar
JST4SHO is an unknown quantity at this point
Old Aug 12, 2009 | 12:12 AM
wlorton's Avatar
I love you!
Fourstar200
Dec 28, 2011 12:41 AM
OILCOUNTRY
Feb 27, 2009 02:46 PM
2001blazer
Jan 30, 2006 10:13 PM
2000WhiteZR2
Jul 26, 2005 09:20 PM
Blaize70
Dec 24, 2004 02:25 AM
