Clearing Head Lights?
Old Aug 26, 2012 | 09:23 PM
budah93's Avatar
budah93 is on a distinguished road
Default Clearing Head Lights?
I have a 98 jimmy and was wondering how hard it is to clear my headlights. I don't like the yellow strips in there. I know i have to put them in the oven but how long does it take and what tools would i need to do so
Old Aug 26, 2012 | 10:17 PM
richphotos's Avatar
If you wanted to bake them apart, its something like 250°F for about 10-15 minutes. then they should just pull apart, as the adhesive that holds the lens to the housing should be soft enough by then, Wear a pair of gloves, it will be HOT. Good luck.
If you want a specific temp (250 i'm pretty sure is right though) Google "baking headlights" and it should come up with MANY results on how to do it.
50lb_cat's Avatar
When I cleared mine on my 99, I just used a heat gun and a small screwdriver to get the "rubber" backing off. I'm not sure about how long in the oven. I figured it would be easier and more controlable with a heat gun. It still took about an hour to do the whole job. I used amber lights in place of the reflectors as well as some black sealant around the edges to make sure moisture doesn't get in.
Old Aug 26, 2012 | 10:22 PM
budah93's Avatar
was it very hard?
Old Aug 26, 2012 | 10:36 PM
50lb_cat's Avatar
No, not hard at all. Just take your time and keep your patience. The end result is worth the work!
Old Aug 26, 2012 | 10:41 PM
budah93's Avatar
does the heat remove the amber film as well?
Old Aug 27, 2012 | 12:26 AM
50lb_cat's Avatar
There wasn't any film in mine. All there is, is some plastic reflectors. If the police are picky in your area, you should put amber bulbs in. Otherwise you are asking for a ticket, trust me, it was only 2 days after I finished the job...lol
Old Aug 27, 2012 | 06:52 AM
richphotos's Avatar
yup, the amber is just a diffuser behind the clear lens.
NVANZEE
Lifting Tech
Feb 22, 2009 09:05 AM
blazerstreetrod78
Lifting Tech
Jul 25, 2008 04:55 PM
bowanna03
Mar 13, 2007 12:57 AM
huskerinaz
Sep 20, 2006 09:16 PM
Bgray
Engine & Internal
Mar 20, 2006 11:42 AM
