dead power seat
Old Oct 24, 2014 | 05:41 PM
sky_blazer's Avatar
sky_blazer is on a distinguished road
Default dead power seat
got a 99 Bravada with heated power front seats. the driver side works fine but the passenger side is totally dead. its a pain to sit in as well since it died in a weird position, most of the way forward and the reclined far back. im thinking its a bad power motor if thats the case how hard are they to swap out?
Old Oct 24, 2014 | 08:14 PM
rexazz2's Avatar
does it move in any other direction ??
should be more than one motor
If no other function is working check the fuses , for some stupid reason I think the left and right seats are separately fused
If the fuses are ok also check the power plug under that seat
Old Oct 25, 2014 | 08:03 PM
sky_blazer's Avatar
ill check the fuses if thats the case maybe there is no power to that seat. i turned the heated seat on and it didnt work. that seat is completely dead no movement no life nothing. i read about 3 wires for the power seats going across floor pans under the carpet then they fuse into one wire by driver kick panel. maybe my truck is too new but ill check
Old Oct 25, 2014 | 08:23 PM
rexazz2's Avatar
check your glove box for an owners manual
There should be a section regarding fuses there
There should also be a plug under the actual seat
Old Oct 26, 2014 | 07:00 AM
sky_blazer's Avatar
ok thanks ill report back with results
Old Oct 26, 2014 | 09:44 AM
sky_blazer's Avatar
ok i checked all the fuses could not find anything that specified the power seats. looked in engine compartment fuse block too. i found the heated seats fuse was blown so i replaced that one and the passenger seat still didnt work
Old Oct 26, 2014 | 02:13 PM
rexazz2's Avatar
did you take a good look for a plug connection under that seat ?
did you check your owners manual for a fuse guide? , index in the back of the owners manual
Old Oct 27, 2014 | 09:16 AM
sky_blazer's Avatar
yes the connection on plug is clean and connected..and yes had owners manual with me looking at the fuses and cavity. the only think i didnt do was check for voltage at the plug
Old Nov 2, 2014 | 08:11 AM
sky_blazer's Avatar
bump.....
94s10blazin
Aug 10, 2013 01:00 PM
TrTl
Sep 22, 2012 09:56 AM
kickme005
Sep 6, 2010 06:03 PM
LilMsChevy
Jan 11, 2010 09:45 PM
rriddle3
Aug 26, 2007 04:38 PM
