Exterior Window Moulding
Old Dec 23, 2007 | 10:16 AM
blazinloud's Avatar
Default Exterior Window Moulding
Anyone have any problems with theirs comming un-glued?
my passenger side kinda does an arc like this (
just unglued in the middle.......any easy fixes or should I just get speedy auto glass to fix it when I get my windsheild replaced?
Old Dec 23, 2007 | 04:10 PM
Chevy Lover's Avatar
Default RE: Exterior Window Moulding
What moulding are you referring to? The drip rail moulding, the outer belt moulding, the glass run channel or the door opening weatherstrip moulding?
And what year was that?
Old Dec 23, 2007 | 05:17 PM
blazinloud's Avatar
its a 98......its the moulding on the outside of the passenger window along the bottom
Old Dec 23, 2007 | 05:25 PM
mdehoogh's Avatar
mine does the same thing. on the drivers door, if the window is down, you can just pick up the molding. its basically justsitting there. on mine, its not quite up against the glass. kinda arc'd like you said yours was. its never given me any trouble so i havent bothered fixing it.
Old Dec 23, 2007 | 08:32 PM
I had this same problem on all 4 doors of my old Bravada. There are little rectangular lugs on the inside edge of the molding itself. Then there are slots in the sheetmetal of the door that are supposed to accept these lugs. I was able to reach down inside with a thin screwdriver and pry out the top of these slots allowing the molding to catch better. Never had a problem with them again. Be careful though, the glass is right there!!
Old Dec 24, 2007 | 03:06 PM
blazinloud's Avatar
k I'll check that out, thanks guys
BigBlackBlazer
Jan 10, 2013 10:50 AM
jimhens82
Jan 28, 2011 10:47 PM
Chipnolike
Apr 8, 2009 09:15 PM
CanadianBlazer
Mar 6, 2008 08:06 PM
megtom2
Oct 27, 2007 11:16 PM
