Gauge cluster lights
Old Nov 20, 2012 | 11:49 AM
99Legendary's Avatar
99Legendary is on a distinguished road
Default Gauge cluster lights
This may be a stupid question.
superbrightleds.com changed their site layout around a little bit and I am some what confused on what I am getting.
I know I need "twist lock" bulbs for my gauge cluster like Thogert says, but I am unsure which ones they are.
(I AM GUESSING THEY ARE THESE?)
NEOx LED Bulb - Instrument Panel LED | Instrument Cluster and Gauge | LED Car Bulbs | Super Bright LEDs
Also, here is the main page for cluster lights. Thanks guys
Old Nov 20, 2012 | 01:33 PM
50lb_cat's Avatar
From what I understand, you need the twist lock base and T10 bulbs, and you buy the base seperate from the bulbs. Someone correct me if im wrong, as I have been debating on doing the LED swap as well.
Old Nov 20, 2012 | 02:39 PM
Thogert's Avatar
Yep, you need the T10 (called 168/194 on the site) bulbs and the bases to match.
Here is the kind of bulbs that are most popular for the gauges.
Here is the matching bases.
Old Nov 20, 2012 | 02:47 PM
50lb_cat's Avatar
Not to hijack, but what do you recommend for the overhead and floor lights thogert, thanks again!
Old Nov 20, 2012 | 10:01 PM
Floor lights are 194 and overheads are 44mm
Old Nov 21, 2012 | 12:39 AM
Thogert's Avatar
^Yep (although I wired in a custom setup on my roof lights.)
Old Oct 28, 2013 | 02:28 AM
CanadianaBlazer's Avatar
CanadianaBlazer is on a distinguished road
Buying red LEDs for cluster ... how many do I need to buy? (including climate control cluster, 4x4 buttons, headlight switch panel, power window/lock switches, etc.)
Old Oct 28, 2013 | 10:21 AM
Thogert's Avatar
Check the link in my sig.
blazerguy09
Jan 7, 2015 03:26 PM
JonZRDeuce
Feb 5, 2012 06:38 PM
Lidberg
Aug 10, 2011 01:01 AM
3kidblazer
Feb 1, 2009 11:22 PM
magtec
May 5, 2006 06:48 PM
