How-To: Mounting Fire Extinguisher and Maglite
Old Feb 25, 2008 | 07:38 PM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Default How-To: Mounting Fire Extinguisher and Maglite
There is another thread sort of discussing this, but I decided to make a how to on how I mounted my Fire Extingusher and Maglite, and made them not rattle while driving.
Here is a link to the other thread.
Materials Needed:
- Fire Extinguisher (Auto/Kitchen Style and size) (Can buy at Walmart for about $15+tax)
- 2,3,or 4 C or D cell Maglite
- Appropriate sized clips for the maglite (I found mine on amazon.com for like $7+shipping)
- You can also use Quick Fists of appropriate size
- Double sided industrial grade foam tape (can be found in automotive area of walmart, made by Duct brand)
- Screws
You will want to layout where you want to mount the items by test fitting again and again.
I chose the jack cover in the rear cargo area to mount both.
I mounted them with doublesided industrial grade foam tape, then put in 2 screws per Maglite clamp (came with the clamps). I did this to hold them in good since they grip the Maglite real tight and I ripped one of the mounts off once already. You could also add similar screws to the mount for the fire extinguisher, I just haven't gotten around to it yet and it has not come loose for the year I have had it installed.
Here is a view of just the mounts:
Showing the Fire Extingusher and a better view of the maglite mounts:
Showing the final product installed:
Here is a view from the rear of the truck with the liftgate open:
Now to make the batteries not rattle in the Maglite:
First tape the batteries together as shown below.
Then get a sheet of loose leaf notebook paper and roll it tightly around the batteries. Taping the length of the paper seam when you are done. Then make sure you can slide the paper tube on and off (so you can change the batteries in the future).
Here is the finished look with the paper wrapped around the batteries
And then insert batteries and paper tube into the maglite
If you have any questions, feel free to PM me or IM me (AOL screenname = lennybritz)
Old Feb 25, 2008 | 07:50 PM
WolfPack's Avatar
Default RE: How-To: Mounting Fire Extinguisher and Maglite
Very nice! Odd that you had a battery rattling issue. I don't have that issue with any of my maglites, then again the only one I carry in the car is a 2C..D's might be a different design..enough to rattle [&:], but good solution to the problem!
Old Feb 25, 2008 | 08:04 PM
Yeah I have the 3-D Cell version Maglite. Also since it is mounted horizontally pretty close to the axle, it pretty much rattled everytime I hit an expansion joint. Not too bad but I didn't have the subs installed yet at that point.
Old Feb 26, 2008 | 02:55 AM
thegr81's Avatar
Nice article, I like the pics!!
Old Mar 12, 2008 | 02:59 AM
trekguy73's Avatar
trekguy73 is an unknown quantity at this point
Thanks for the tip. Looks great.
Old Mar 14, 2008 | 05:34 PM
jimmyboy's Avatar
jimmyboy is an unknown quantity at this point
that looks really cool. and pretty easy to do.
jimmyboy
tall_ish
Nov 20, 2010 09:05 PM
Red 96'
Aug 23, 2010 04:27 PM
jimmyboy
Jun 23, 2008 10:59 PM
MVPalmer271
May 30, 2007 07:28 PM
vagnozzi
14
Apr 27, 2007 12:33 PM
