int door panel removal tips?
Old Oct 18, 2012 | 01:21 PM
TDS-MN's Avatar
TDS-MN is on a distinguished road
Default int door panel removal tips?
Hey All,
Have to remove the Driver's door interior panel, have a broken rear-view mirror to fix. Any tips and/or tricks to make this task simple and pain-free for a first-timer? This is on the '98 Blazer. My first quick glance at it did not reveal any visible fasteners or anything. Thanks!
Old Oct 18, 2012 | 03:17 PM
50lb_cat's Avatar
There should be 3 screws. 2 are at an angle below the door pull and one is holding on the plate that covers the door handle. (At least on a 99 jimmy, should be about the same). Then they are held on by a bunch of plastic "christmas trees" that just pop off. They make special plastic pry bars but you don't really need em. Just take your time.
I assume you are talking about the side view? When you get the panel off, there will be 3 rubber plugs hiding the bolts for the mirror. Pull out the plugs and undue the bolts, careful with the last one or it will fall lol. If you have power mirrors, there's an electrical connection to undue as well. Easy job. Hope this helps.
Old Oct 19, 2012 | 07:21 PM
99lsdriven's Avatar
99lsdriven is on a distinguished road
On my 99 blazer, I believe the only screw for the front doors is in the cover for the door the rest of the removal process is just the "christmas trees" (jacking cats term because I have no clue what they are called).
Old Oct 21, 2012 | 06:18 AM
TDS-MN's Avatar
Thanks to both of you, that info will be helpful. I know those press-in 'christmas tree' fasteners you speak of, good to know what I'm going to be dealing with. Yes, I did mean the side view mirror, not sure why I mis-typed that earler. Does not seem as if I should run into anything unexpected when I get a chance to tackle this project.
Old Oct 21, 2012 | 04:00 PM
99lsdriven's Avatar
Nope, definitely one of the easiest door panel removals I have ever done was on my blazer
Old Oct 28, 2012 | 06:57 AM
TDS-MN's Avatar
Default done!
yes, that project is now on the "Done" list. It was as easy as described. Those 2 screws under the door pull handle were difficult to see, but easy enough to remove and replace. The mirror attachment was super-easy to get to as well.
Was replacing a partially broken off side mirror. Found both of the lower mounting studs to have broken free from the mirror, due to an impact the mirror suffered.
I believe that the one I scored from the salvage yard is an aftermarket piece, and not a GM part. The adjuster motor is LOUD. (Just like the one I installed on a different one of our cars, that I know was non-GM.) Disappointed in that a little bit, but the price was hard to argue with I guess.
Old Oct 29, 2012 | 07:19 PM
richphotos's Avatar
Hey, another Minneapolis member. Glad you got the panel off. Its quite simple. harder to get it back on than it is getting it off.
Tenthjester65
Apr 24, 2014 05:39 AM
teamrojas
Jan 21, 2013 12:30 PM
jkmzr201
Jun 12, 2011 11:16 AM
shade tree
Feb 4, 2011 08:26 AM
pusher_sr
Jan 24, 2006 07:58 PM
