Need help finishing swap 5.7 99 Blazer backfire
Old Nov 9, 2021 | 10:08 AM
Chad Colegrove's Avatar
Chad Colegrove is on a distinguished road
Default Need help finishing swap 5.7 99 Blazer backfire
I finished my swap on my blazer everything is hooked up it's just backfiring and not completely starting I keep going over the timing but it doesn't seem to change I used the crank sensor for my V6 vortec cuz it is the same part number any suggestions should I try using starting fluid maybe the gas is not getting up to the carburetor where the throttle body I meant to say and with that should I get rid of my spider injection and use the old system
Old Nov 10, 2021 | 08:01 PM
eshaw's Avatar
Did you change the ECM when you did the swap? How about the distributor, was it removed and replaced?
Maudh Alraggad
Aug 1, 2020 08:02 AM
Doug B
Jan 25, 2020 11:37 PM
S10BlazerFTW
Aug 8, 2013 09:39 AM
young_hunter05
Nov 10, 2010 05:28 PM
ChevyBlazer1989
Jul 6, 2009 07:43 PM
