paintable interior?
Old May 4, 2008 | 01:01 AM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
Default RE: paintable interior?
i used dupli-color vinyl and fabric
http://i277.photobucket.com/albums/k...0/IMG00032.jpg
I found that that prep spray isnt that good it leaves a greasy residue on the plastic, so i just used some mineral spirits then some dish soap and water, then rinsed it with water then dried with a towel. here's how it turned out
http://i277.photobucket.com/albums/k...0/IMG00030.jpg
http://i277.photobucket.com/albums/k...0/IMG00029.jpg
http://i277.photobucket.com/albums/k...0/IMG00028.jpg
I plan on doing the ash tray and the whole center counsel tomorrow if i have time and its not that humid/rainy
Old May 4, 2008 | 06:19 PM
neo71665's Avatar
It's ya'lls trucks but I wouldn't use krylon, unless its done carefully it looks too thick. I know it clogs sandpaper bad if your trying to wetsand it smooth.
The method I use is to sand all my parts smooth first starting with 80-150-400, then I use bulldog adhesion promoter, then a high build primer. I smooth that with 400 then reapply if needed or start painting. I put 4-6 coats of paint on the part then start wetsanding with 600 or 800 being careful not to sand down to the primer. Once I have it all smooth with a good layer of paint I clear coat it. I lay a couple of layers of clear down then wetsand it with 1500 being careful not to cut through the clear. Then I either respray or start with polishing compound to bring the shine back to the clear.
So far I've done 2 trucks and everything but the dash from the doors forward in my blazer with good luck doing it this way. If your wanting to do any soft plastics like the dash you need to lay a layer or 2 of fiberglass down first then paint that.
Old May 7, 2008 | 03:52 PM
Mickeymouse's Avatar
Mickeymouse is an unknown quantity at this point
Ok, nice pics of your interior djdrew010....hope that you will show the rest of it when you're done....
Anyone else how have some pics to show?
Lots diffrent methods you all use, I'll have to go to the paintshop tomorrow and check out what they have??
Thanks for your ideas..
Regards Michael
Old Sep 13, 2008 | 01:27 PM
TheSzokes's Avatar
TheSzokes is an unknown quantity at this point
would the interior paint stick good to the fibreglass? and what is wetsanding
Old Sep 13, 2008 | 06:16 PM
neo71665's Avatar
Yes it sticks to fiberglass.
Wetsanding is just what it sounds, you use water to help lube and clean the paper and it gives a smoother finish. You don't have to have water running over it the whole time but I use a cheap spray bottle and keep the part wet.
marksoftball
Mar 16, 2014 04:55 PM
Dutch_EXP
May 3, 2009 01:09 PM
zero psi
Nov 13, 2005 04:07 AM
Biohazrd
Sep 13, 2004 10:43 PM
drewminator33
Sep 1, 2004 12:00 PM
