rear cargo area mod??
Old Jul 9, 2010 | 08:55 PM
warthogdriver's Avatar
Default rear cargo area mod??
ok, well since i have the rear tire carrier on and the space where the tire was under the rear cargo area is empty, here is my thought.
has anyone actually cut away a portion of the cargo area floor and dropped in something like the pan that would carry and spare in...say a car trunk.
i am thinking that would be good use of wasted space and free up my cargo space. i carry tool boxes and such and they have become permanent fixtures in the rear...so i figure i can cut away floor...drop in / make a space to carry this junk and then slide plywood with carpet / hinge over the space and...taaa daaa space saved...area cleaned up.
my only concern is there for any reason (i cant think of one) a structural issue with doing this?? am thinking of staying well within the frame line.
Old Jul 9, 2010 | 09:38 PM
Benedict1337's Avatar
that's not a bad idea.... I know about an inch or 2 under the floor there is the tire support not sure if that has structural value or not. I was scheming on mounting a compressor under there for some train horns...
Old Jul 10, 2010 | 01:46 PM
butters's Avatar
butters is an unknown quantity at this point
yes it has been done, check through some blazers on cardomain.com i have scene a couple on there that created rather large storage under there. idk about a tire if you are running anything bigger then stock. and as far as strenth i would not worry about it the flooring is thin and doesnt do anything for that. a good solid pan would probley improve the strenth of it.
Old Jul 10, 2010 | 01:57 PM
i figure i could make it at least the same size the tire was. the only hang up i have is that the tire being gone makes for great working room back there underneath.
but i do like the idea of space saving...thanks for the car domain tip i will check it out.
blazen_red_4x4
Jan 23, 2015 12:46 PM
Nick_K5_Blazer
Nov 25, 2011 02:42 PM
carterx
May 15, 2009 03:43 PM
rdhack
Apr 11, 2008 08:13 AM
Schmev
Nov 15, 2007 08:48 PM
