remove rear window trim? how?
Old Nov 18, 2007 | 06:15 AM
brunosrk's Avatar
brunosrk is an unknown quantity at this point
Default remove rear window trim? how?
The right rear side window on my 2nd gen (03) 2 door seems to be leaking. How do I get the exterior trim off to see if the glass is sealed properly?
Old Nov 18, 2007 | 02:00 PM
Chevy Lover's Avatar
Default RE: remove rear window trim? how?
[ol]Remove the upper and lower front seat anchor bolts.
Remove the rear seat belt lower anchor nut.
Remove the assist handle.
Remove the coat hook.
Remove the endgate or the liftgate opening door sill trim plate.
Fold the rear seats down.
Remove the jack storage cover (left side only).
Remove the screw that retains the upper body side trim body side trim panel to the vehicle (left side only).
Remove the upper body side trim panel from the vehicle.
Feed the seat belt through the trim panel. [/ol]
Old Nov 18, 2007 | 02:55 PM
brunosrk's Avatar
Thanks for the reply, but what do those instructions have to do with the EXTERIOR trim?
Old Nov 18, 2007 | 03:25 PM
By removing the interior trim and using a garden hose on the outside of the window, you can narrow down where the water is coming in through. Looking at it from the outside (if you even can) won't tell you the whole picture.
Old Nov 18, 2007 | 10:21 PM
ORIGINAL: brunosrk
Sorry, just my impression of what you needed. I looked to see if you had a photo gallery or even a pic of your truck and couldn't find one.
I thought that you were referring to the stationairy side glass, which is sealed in place with urethane and I don't know how you would see that from the exterior, so I thought you meant INTERIOR trim.
blazerguy22
Mar 30, 2019 09:47 AM
hace1
May 30, 2012 11:34 AM
okvortec
Dec 8, 2009 06:25 AM
blazerguy22
Oct 13, 2009 02:54 PM
CraigSnedeker
Oct 6, 2009 12:52 PM
