Removing Stickers
yahh i've used goo-gone, wd40, lighter fluid, was even told gasoline works (haven't had the opportunity to try that out though), and Pb-blaster...industrial wd40 and a finger nail *after using my ice scraper in winter to pry off all the chevy&blazer emblems* lol which doesnt matter the scratches are soon going to be taken care of.. or one of those hot hands...i found work too...get it hot stick it on and alternate between a hot gun and heating pad and wd40 fingernail and shop rag.. its soooo easy lol almost any thing with ethanol or any thing that has a strong alchohol odor i've found works its even come down to using mouth wash...listerine...just takes a little longer...
hello snap on makes a crug thug that uses a rubber cog whell to remove decal and glue cost 300-400 dollars. astro also makes one that uses a solid rubber wheel works well cost used to be around 130 dollars with 12 wheels .
both will also remove two sided tape that holds on body side mouldings then clean up with wax and grease remover thanks and good luck
