tire holder mod
Old Jun 26, 2012 | 01:42 PM
jrb_fishy's Avatar
jrb_fishy is on a distinguished road
Default tire holder mod
i have the 1998 blazer base model now i see the zr2 with the back tire holder and because i have custom rims i cant mount my tire under the truck so i want to put the rear holder on so my rim does not get messed up can somebody tell me what steps i need to take to make this happen on my model i know there is going to be some customization to the body of the truck
Old Jun 26, 2012 | 01:59 PM
50lb_cat's Avatar
Check out the DIY section or search for " so you want a rear tire carrier" long thread with lots of useful pics and info
Old Jun 26, 2012 | 02:43 PM
rexmburns's Avatar
Super Moderator
Click here!
Old Jun 27, 2012 | 09:01 AM
neo71665's Avatar
Build bumper with swing away carrier. Unless its a street queen since your don't have the bracing inside the body the weight of the carrier will cause body damage. Factory installed they have bracing welded inside that's A. Hard to remove B. Hard to install unless you remove the body skin and reinstall it. Fender washers might be fine for a bit but if the truck sees any kind of offroad use with bumps it will jar and shake the carrier leading to cracks in the body. Over time the bolts WILL pull through.
mr.vls
May 28, 2010 09:08 PM
88Vic
May 14, 2010 12:08 PM
renswic
May 18, 2009 10:24 AM
Bosaliniee
Jan 30, 2007 03:27 PM
guywm25
Jul 17, 2006 11:39 AM
