What size rim/tires
on a stock suspension set-up for a 02 Chevy Blazer 4x4 4dr S-10
if i did go with large rims and low profile tires what would the biggest rims i could do, what is there bolt pattern size
and what size low profile tires would i need
so that i could fit bigger rims succesfully
depending on the uses of your blazer, i would suggest that you dont put such huge rims on. with that low of a rubber on, you will be bouncing all over the place. all the bumps of the road will hit the truck and the 4x4 suspension wouldnt be to fun. If your just going to be using it on the road, then you would be fine. but if you plan for any time in the mud and such, i would suggest something like some 16-17's with a meaty truck tire.that way you get the best of both worlds.
evuldrporkchop
Mar 4, 2013 01:20 AM
Spectreblazer
Feb 13, 2010 04:59 PM
