Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
4.3 Vortec Rebuild
Old May 13, 2010 | 06:45 PM
Champion69's Avatar
Champion69 is on a distinguished road
Need some advice to rebuild my 94 Chevy Blazer Vortec 4.3 liters
Hi everyone!
Two weeks ago, my wife try to start our 94 Blazer, and just nothing... simply the engine doesnŽt start, only sounds the click at key action, like the battery was dead, the motor doesnŽt turn.
IŽve start to tear down the motor in order ti find the problem (I expecting something simple) first of all, i found water, near a quarter, once drain the oil from the motor... maybe you figured out.. here is what finally i discover...
Please, from now iŽll need and very appreciate all advice to rebuil my engine, this is de first major reapair since i bought my truck in 1994 0 miles... today has 210, 003!!! and always runs good!!! I love this truck, I think this excelent machine deserves a new and long life... I expect 100k miles more!!!
Thanks in advance.
Cyl. #6...
Last edited by Champion69; May 13, 2010 at 09:02 PM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old May 13, 2010 | 08:05 PM
With that kind of damage, you may want to look into a crate motor. Your block/heads may have been compromised.
Old May 13, 2010 | 08:09 PM
Champion69's Avatar
Default #2
Once I detached the #6 piston...
My truck is a 4wd, vin W... should I change all other 5 rods or is acceptable change just this dmaged connecting rod?
Old May 13, 2010 | 08:25 PM
Champion69's Avatar
Hi, Swartlkk.
What kind of damage do you think block or head could have? I inspected the cylinder and no has scratches or dents, iŽll try to check alignment, no twist or bending condition of the heads... I turn manually the engine (properly lubricated) after I detached the piston #6 and iŽve not noticed any other obvious problem, What do you think if I change only this damaged part?
Old May 13, 2010 | 08:29 PM
To bend a rod like that, you had to have hydrolocked the cylinder. If everything checks out as flat (you need to check them with a precision straight edge), then you may be ok, but you may want to have the heads and block magnafluxed (magnetic crack detection) to make sure there are no cracks.
Old May 13, 2010 | 08:48 PM
Champion69's Avatar
Shure, IŽll do that as a first step.
In other issue, How can I check the proper function of the oil pump? I mean, now, that it removed, I donŽt want to see low pressure when the engine is assembled, Thanks.
Old May 14, 2010 | 05:34 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Oil pumps are routinely trplaced at overhaul. Just btrak down and get a new one. They're pretty cheap.
aksallday
Sep 12, 2013 01:21 PM
76 Ranger
Mar 21, 2012 08:17 PM
Chevy8493
Dec 9, 2008 11:34 PM
dbinnc
Oct 11, 2008 12:59 PM
88s10Blazer
Dec 25, 2007 09:29 PM
