Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
4.3L Performance on a budget
Old Apr 28, 2008 | 03:29 PM
Brian Mooney's Avatar
Brian Mooney is an unknown quantity at this point
Default 4.3L Performance on a budget
Hello, I was looking at the 350 conversion, and am kind of interested in it, but not the way gas prices are going. I've gotan 02' Blazer LS. I'm wanting to upgrade the motor a bit, maybe put some cams in it and/or intake manifold, bore the throttle body possibly, is there anyone that knows anything about this? Can i even buy some mild cams or an intake manifold?
My car has 64,000 miles on it, and is slower than dog poop. I was even thinking about buying my friends Nitrous kit for $125.
Would this be a solution, how much can you necessarily spray on these motors safely?
Old Apr 28, 2008 | 09:12 PM
Default RE: 4.3L Performance on a budget
Welcome. I will suggest that you browse through the forum for a bit and maybe try some searches to see what others have tried. The topic of nitrous on these motors has been covered fairly well by 02Vortech. Cams have been covered most recently in a few threads, but the cost might be a bit prohibitive...
Let us know if you still have some questions after reading through a few threads and please try to link to those threads that you have read so we don't duplicate previously suggestions.
Good luck and keep us posted.
Old May 1, 2008 | 11:23 PM
95LS's Avatar
95LS is an unknown quantity at this point
my advice would be to start with the small stuff. headers,exhaust,throttle body,cai, and then work on the bigger things (cam,heads.....) that is if you dont want to do a engine swap. i think youll be better off in the long run that way.
Old May 5, 2008 | 04:53 PM
SmokeU's Avatar
SmokeU is an unknown quantity at this point
i would go with the engine swap
Old May 22, 2008 | 02:01 PM
The A Team's Avatar
The A Team is an unknown quantity at this point
ORIGINAL: SmokeU
x2 i think i have done pretty much every bolt on with mine and i have NOT noticed any power improvements. Millage i think went up about 2-3 mpg though [sm=smiley1.gif] to a remarkable 19 mpg. [sm=sigh.gif]
Old Aug 14, 2008 | 07:52 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
i have done alot too.. cant seem to get mch more out of mine either... try a hypertech tuner, k&n intake and exhaust... thats what i did and i beat stock blazers...
Old Aug 15, 2008 | 02:09 PM
Duntov's Avatar
Banned
Duntov is an unknown quantity at this point
Unfortunately, the 4.3L TBI was at optimum power output when it cameoff the factory assembly line. Very little,if any, power improvements can be made with buget aftermarket modifications. The 4.3LTBI engine needs all the low end torque it can muster and if a hotter cam is installed such as a GM marine cam or a aftermarket cam withhigher valve lift andlonger valve duration, you will only succeed in killing what little low end torque the 4.3L engine possesses.
The improvementsyou can make to the4.3L engine is fordurability byusingthe following parts:
Ross#90459 +.030" OS, 350 Chevy V8 forged aluminum pistons with .0035" skirt clearance;Cloyes 9-3100C timing set; GM-12363753 2.02" x 4.880" intake valves;Melling #10555 oil pump; .750" ID Melling #259S or Sealed Power #224-14263 4WD pick up screen assy.; Melling IS-55E steel oil pump drive shaft; Comp Cams #7940 High-Tech 5/16" x 7.200" chromemoly pushrods; Crane 270-99148-2 rocker studs with3/8"-24 top x M10-1.5"bottom threads which willreplace stock screw-in rocker studs or install V8 GM-12495497 rocker studs, 3/8"-24 top x 7/16"-14 bottom threads which willmachining to replace OEM pressed-in rocker studs; GM-3927142valve springs with 110 lb. @ 1.700" seat pressure; GM-14011051 guideplates;Eagle H-beam CRS570063D,5.700"steel 4.3L V6 or resized OEM5.700" 4.3L V6 rods with SB Chevy ARP bolts and you must totally internally balance the engine. For more horsepower and torqueuse nitrous oxide or install a turbocharger.
The power limitations of the 4.3L V6 is why GM installedturborchargers on the 1991 Syclone and 1992 Typhoon engines and did little else.
PawNtheSandman
Headers, Intake, & Exhaust
22
Jul 10, 2008 07:12 AM
stevenf
Lifting Tech
14
Apr 29, 2008 11:33 PM
gohan69
Aug 27, 2007 08:16 PM
BlaZeR FXB1581
14
Jan 7, 2007 04:03 AM
athleticdawg26
Aug 10, 2006 04:33 PM
