Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
99 Blazer LS 4dr....v8 swap???
Old Oct 22, 2010 | 06:08 PM
white99ls's Avatar
white99ls is on a distinguished road
Default 99 Blazer LS 4dr....v8 swap???
Hello all..this is my first post as I've been plenty informed without having to ask since plenty have asked before. I apologize in advance if its been asked and i missed it but......
My 99 S Blazer runs fine but that doesn't mean i don't need to "fix" it. Although I have the utmost confidence in the 4.3Vortech i'd like to put in a v8. Ive seen an 89 with the drivetrain out of a 99 full size truck. If i recall what i read somewhere it wold be possible to get a 99/00 5.7 and plug and play(the ignition and emmision pc stuff) even use the same TB. I know fabbing some things is required, but making it look like GM was smart enough to do it would be nice. ANY and ALL expirence ideas starting point or info is appreciated from my fellow Blazer owners....oh..I'll put up some pics tonite
Old Oct 23, 2010 | 12:29 AM
69chevelle's Avatar
69chevelle is on a distinguished road
search 5.7 2nd gen, lots of info on it
not hard, but not plug and play.
little wiring, mounts, exhaust work cooling modifications, computer re-tune. and the crank position sensor re-calibrated
2wd is easier then 4. 4wd requires custom oil pan unless you use the advance adapter 4.3 mounts which raises motor up a couple inches, but requires a body lift or cowl hood to close the hood.
80's camaro 305 low output manifolds fit the best clearance wise but won't get as much power as conversion headers
Old Oct 23, 2010 | 11:48 AM
white99ls's Avatar
thanks for the info....I'm going to start putting a grocery list of things together so i can make this a "single weekend without leaving the shop til it's done "project
Old Dec 11, 2010 | 03:14 PM
stevo's Avatar
stevo is an unknown quantity at this point
good luck with that hahaa
Old Dec 11, 2010 | 08:12 PM
69chevelle's Avatar
It's possible with the right tools and parts...
Old Jan 2, 2011 | 11:30 AM
BadA$zBravada98's Avatar
BadA$zBravada98 is on a distinguished road
if you are looking into performance gains then maybe you should check into the ls series as opposed to the vortec 5.7? the 5.3 ls is said to make more power and with simple planning ahead of time it would be possible to do in 1-2 weekends....... just a thought
Old Jan 2, 2011 | 02:51 PM
KM346's Avatar
KM346 will become famous soon enough
Search for Jags That Run... their website is a little confusing but they sell a bunch of parts necessary for a second gen 4x4 v8 swap. They also sell an engine swap book.
Racingxtreme8
Feb 25, 2011 03:02 AM
white99ls
Jan 23, 2011 11:57 AM
pctechdude
Nov 24, 2009 10:23 PM
blazinon22s
Sep 17, 2007 10:12 PM
SMBrandono5
Jan 22, 2006 12:43 PM
