Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Disc Brakes
Old May 22, 2007 | 10:18 PM
viper4559's Avatar
viper4559 is an unknown quantity at this point
Default Disc Brakes
Hey all,
My dad has a friend in DC that said stay away from the drilled brakes because they will warp do to the rapid changes in temp. I was just curious what you all knew about the drilled/slotted disc brakes. I am currently planning on going with slotted discs and new pads and calipers when I get the money, but I wanted to know if it was worth it, or if I should just stay with the stock rotors?
Thanks,
Viper
Old May 22, 2007 | 10:37 PM
Default RE: Disc Brakes
Slotted rotors have their benefits over stock flat rotors.
On the issue of drilled rotors, well, it all has to do with when the holes are put in the rotor. If they are drilled after casting, then the rotors are inherently weaker than stock and many have a tendancy to crack and come apart. Some have had decent luck with drilled rotors, but the fact that some have had catastrophic failures with them is enough to keep me from using them. And rotors that have cast in holes, which are much stronger, are just WAY too expensive and for our case, aren't even available.
Old May 23, 2007 | 08:22 PM
viper4559's Avatar
But slotted rotors will be alright? No falling apart, no doing something bad that will cause me to die!?
Old May 25, 2007 | 04:58 AM
drperry's Avatar
Slotted rotors will do ya great! Stick 'em with a good pair of pads and you'll be stoppin' on a dime, lad.
Old May 25, 2007 | 10:49 AM
viper4559's Avatar
What are some good pads to look into? good brand names that is....
Old May 25, 2007 | 03:13 PM
drperry's Avatar
As to that, I can't say... For my Z34 and S10, I bought bottom of the line cheap stuff (full set of rotors and pads for the Z34 was less than $100 Canadian, lol)
When the brakes are due on the Blazer, I'll be researching it...
Old Jul 19, 2007 | 12:49 PM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
I like Bendix, myself. They last a long time and are built tough.
Old Jul 19, 2007 | 11:31 PM
viper4559's Avatar
Well I ordered Power Stop slotted rotors and Hawk HPS pads for my front end back on the 8th of June from Cardomain.com, they still have not shipped or charged me. I called in earlier this week and the guy was supposed to call me back the next day with a time of expected departure. not real happy, but its the cheapest I could get all of it for, maybe even cheaper if they discount it for the problems :-)
Old Jul 20, 2007 | 03:01 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Drilled also tend to crack.
poertsch
Apr 23, 2016 01:05 PM
Mark_D
Apr 29, 2011 11:40 PM
fnirish
Dec 30, 2008 06:47 PM
felonyblazer96
Tires and Wheels
Nov 23, 2007 05:44 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
