1999 Blazer 2WD leaking differential oil from wheel
Old May 6, 2015 | 01:51 PM
krzldy1949's Avatar
krzldy1949 is on a distinguished road
Default 1999 Blazer 2WD leaking differential oil from wheel
I replaced the brakes but have differential fluid leaking. Do I have to remove the wheel, rotor, caliper etc and can I get to the bearing and seal that way or do I have to go through the differential? Thanks,
Old May 6, 2015 | 07:16 PM
krzldy1949's Avatar
I got everything off except stuck at little c clip in differential... any help?
Old May 6, 2015 | 11:40 PM
Rusty Nuts's Avatar
Push the axle in a little and use a magnet.
Old May 7, 2015 | 03:24 AM
krzldy1949's Avatar
how do you push the axle in? a guy on a u tube video popped the clip off with a screwdriver? tried that but unsuccessful. do I still need to remove the rotor, caliper, brskes etc? thank you
Old May 7, 2015 | 11:40 PM
Rusty Nuts's Avatar
Yes. The brakes have to be removed to slide the axle out. Make sure the instructional videos you're watching are for a GM 10-bolt differential. Also look at pictures of normal and excessive bearing wear patterns on the axle. If your axle shows too much wear, your new seal won't last.
Old May 8, 2015 | 10:32 PM
odat's Avatar
have you removed the center shaft - if not it has to be removed before axle will slide in - shaft is held in by one bolt in the carrier
latunguley
Nov 17, 2014 09:15 PM
Drew4711
Oct 6, 2012 12:47 PM
roscommon1
Feb 8, 2012 12:10 PM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
98BlazerLT4x4
Mar 4, 2008 06:00 PM
