1999 Chevy Blazer 4x4 Rear Axle Assembly replacement
Old Mar 1, 2021 | 10:08 AM
MikeBilak's Avatar
MikeBilak is on a distinguished road
Default 1999 Chevy Blazer 4x4 Rear Axle Assembly replacement
I need to replace rear axle assembly on son's 1999 Chevy Blazer 4x4 (Base trim) GU6. Will a rear axle assembly GU6 from 1999 Chevy Blazer 4x4 LS or Limited trim work? I have looked at several photo for rear axle assemble listed for 1998 to 2003 Blazers GU6 and all of then show different mounting brackets setups welded on the rear axle housing that look nothing like the one we just removed.
Any information would be greatly appreciated.
Thank You
Old Mar 1, 2021 | 11:58 AM
Same rpo gear code and 4x4 is what your looking for, also if you find one with a g80, that helps.
Old Mar 1, 2021 | 11:59 AM
Can you post pics of the different mounts you mentioned? Just remembered you wrote that.
Old Mar 1, 2021 | 12:02 PM
I don't know if it will help you, but here's a picture of the rear axle I took out of my 2000 LT.
Old Mar 1, 2021 | 12:05 PM
Looks the same as my 99, so if it looks like that, then your good.
Old Mar 1, 2021 | 03:07 PM
MikeBilak's Avatar
Thanks to all that responded.
I got all the information I was looking for. Found a rear axle assembly from a 2000 Chevy Blazer LS 4X4 (GU6) with 113K. The one we removed from vehicle has 256K.
Thanks again.
Diane Elliott
Feb 21, 2020 12:04 PM
Red Loctite
May 30, 2016 09:50 PM
hcii
19
Apr 19, 2013 04:20 PM
W2JGA
Jan 20, 2009 05:31 PM
