2001 Blazer - 4wd switch problem
Old Sep 22, 2014 | 06:37 PM
gmagg's Avatar
gmagg is an unknown quantity at this point
Default 2001 Blazer - 4wd switch problem
Having a problem with my 4 button 4wd dash switch. I haven't found a post with a similar issue, so I'll have to ask for help.
Occasionally, as I'm driving (in 2 HI), I'll notice that the LED in the 4 LO button will be blinking. If I press the 2 HI button enough times, the 4 LO light will stop blinking. Usually this situation reoccurs several times before it will stop altogether. Other than the 4 LO button doing this, the 4WD works fine.
Any suggestion? I'm hoping it is just a dash switch problem!
Thanks
Old Sep 22, 2014 | 07:14 PM
There are a few threads out there on the phantom engagement. It is usually caused by corrosion at the TCCM located behind the passenger side kick panel. If you are lucky, a simple cleaning of the connection terminals in both the TCCM (male pins) and the connector (female receptacles).
The link below is to a tech article I put together that shows the wiring and connector pin outs for the NV236 transfer case controls as well as the resistance values for the dash switch:
NV236 Wiring & Diagnostic Information
Old Sep 23, 2014 | 12:07 AM
gmagg's Avatar
Thanks for the info and the link to your article. I appreciate your help.
robtech68
Jan 3, 2015 04:37 AM
hwolfe
Oct 28, 2012 08:08 PM
adasaari19
Mar 10, 2012 09:42 AM
BearingEater
Jun 17, 2011 03:16 PM
JLeigh34
Jan 7, 2010 02:47 PM
