2003 4WD with squeak in front suspension?
Old Feb 24, 2016 | 11:08 AM
jimspahr@msn.com's Avatar
Default 2003 4WD with squeak in front suspension?
This is a loud, annoying squeak in front end. 2Door has 97 k miles and is stock down to the tires. It squeaks when you turn the steering wheel left or right. It squeaks when you go over any bump, even a speed bump. If you push down on the front bumper, it sqeaks. I have just replace the passenger side wheel hub/bearing and no difference in that side. IOW it still squeaks. It has the original Bilstien shocks. I have not lubed the front suspension. What can cause this squeak? How do I test for the cause? Any ideas?
Old Feb 24, 2016 | 07:31 PM
I seem to hear the squeaking only at low speeds. At highway speeds, there are so many other noises, the squeaks may be covered up.
Old Feb 24, 2016 | 08:34 PM
odat's Avatar
you said it squeaks when front bumper is pushed down, get under it and have somebody shove it up and down - not only listen for it feel as well a lot of times you can feel it better than hear it - If that fails and only if that fails, do the same with the other person bouncing it and grab a can of WD and spray one point at a time and see if you can pinpoint it - WD evaporates and won't hurt anything
Old May 28, 2018 | 11:45 PM
WalkGood's Avatar
WalkGood is on a distinguished road
Did you ever find & solve the squeak noise?
94s10blazin
Sep 24, 2018 10:38 AM
WickedBlazer
Sep 12, 2012 03:14 AM
4x4Chevortec
Apr 11, 2011 02:15 AM
thrash902
Sep 15, 2010 10:52 PM
Drey
Dec 30, 2008 03:44 AM
