4 wheel drive cable
4 wheel drive cable
The 4 wheel drive cable jumps and chatters and moves up and down ,when you turn the wheels . The vacuum actuator was all the way out ,when the cable was un hooked it sucked in real fast ,now we can not move the cable ,would the cable be froze ? This is a 2000 S10 Blazer 4x4 everything is auto on it , it has been sitting for 2 1/2 years .
We are going to take the vacuum actuator cable outtoday ,this is connected to the output shaft tube flange ,any ideals on this ?
RE: 4 wheel drive cable
It is very likely that the cable is froze. Can you move the cable by hand?
No cable does not move
That would be my first guess is a froze up cable. If you can get some spray lubricant onto the cable and start to work some movement into it, you should be able to get it freed up. If not, then you will have to replace it.
Could it be a chance that any of the gears could be stripped out ,we do not know how long it was drove with the cable froze,
The indicator switch was undone not plugged in can not firgure out how it plugs back in , do you think maybe something have slip down into this .
The only thing that frozen cable did was keep the front drive axle spinning the transfer case. No gears to strip. No dammage. Poor gas milage. But no dammage.
mirrorimij
06-08-2019 03:34 PM
TexasRider
05-30-2013 09:10 AM
Squad-6
04-22-2013 02:19 PM
lizzj70
06-23-2010 06:57 PM
blazerduo
12-17-2009 10:54 AM
