40" tires requirements
Old Apr 19, 2020 | 09:38 AM
SVPAM_SVPAM's Avatar
SVPAM_SVPAM is on a distinguished road
Question 40" tires requirements
Hi Guys
I need you to help me technically and to suggest products / package
For 1978 GMC Jimmy 4WD stock manual trans with 454 swap with Stock 6 lugs axles
I am planning to go for 40" tires and I don't have a problem on fender trimming
1- What modifications I need in the car ? Chassis, body, wheel spacers, shorter front or rear axles ? Anything required for safety ? I am looking for minimum lifting possible to install the 40" tires. I will not go that much aggressive in off roading
2- I am thinking of superlift lift kit
https://superlift.com/product-detail/K424
What do I still need ? do you suggest another brand ? I am looking for min lift kit that can handle 40" tires to be more durable and safe
What do you advice ? Note that lift kit comes with raised steering arm
3- What about drive shafts, 6 lugs axles upgrade to 8 lugs ? , transmission spacers , steering upgrade, suspension hangers, dual steering dampers, suggest pinion and ring ratio ?
4-I've selected tires 40X13.5X17, what is the recommendation for wheel selection ? 17 X 9 or 17 X 10 ?
Thanks for your help
Old Apr 19, 2020 | 11:21 AM
If you trim the fenders enough, you don't need any lift at all. But that kit you linked should get you by with minor trimming, if any. Especially if you're not planning on any aggressive off-roading. Your stock axles are fine for cruising shopping malls, but you'll want to upgrade to at least a 14-bolt semi-float rear axle for anything more than that. The front Dana 44 will be ok with mild use. If you break axle shafts, you can upgrade to chrome-moly. You'll also want to change the differential gears to 4.56 or 4.88, depending on how much you plan to drive on the freeway. You'll also need to have your driveshafts lengthened and add a good steering stabilizer. I would probably install a reinforcement kit for the steering box, since those tires will put a lot of stress on the frame.
And, to answer your last question, I would probably mount those tires on 10" wide wheels.
Check out Off-Road Design, too. They're not exactly cheap, but they are the square-body Chevy experts, IMO. Besides offering tons of good products, they're also good people who don't mind answering questions on the phone.
Old Apr 19, 2020 | 04:48 PM
Thanks Tom
So 2"or 4" lift kit with minor fender trimming is going to be OK ? What about body lift ? is it recommended in my case ? or I go for lift kit only ?
I have 8 lugs front & rear axles from 1983 Suburban Manual Trans. I can use them even before I start the project, what do you think ? Is it much stronger than my stock 6 lugs ?
Moly or 14 bolts are expensive
For gear I can go for 4.56 or 4.88 no issues, but why ?
My highway drive is maximum 80 MPH
I have 3 speeds manual trans. But I may go for manual 5 spds 90's trans if this better
For performance I'm not planning for high HP I am looking for torque for off road application
LT headers, Holley carburetor, Solid cam thumper comp cams, valves, springs, timing chain, pushrods. Stock cylinder heads
How I can length my drive shafts ? is it extension ? or better to customize it in the work shop based on actually dimensions ?
For steering stabilizer I am thinking to get this kit. It should fit with both 6 & 8 lugs
https://skyjacker.com/shop/steering-...izer-dual-kit/
For steering reinforcement kit, can you help to send me link of this product
What about suspension hangers, any recommendations ?
Sorry for the long reply
Old Apr 19, 2020 | 05:15 PM
Originally Posted by SVPAM_SVPAM
Thanks Tom
The kit you linked to was 8". A 2" or 4" kit will require major trimming. For reference, my last K5 had 7" of lift (6" suspension plus 1" body lift) and still required substantial trimming on the front fenders to clear 37" tires when rock crawling.
The Suburban rear axle is probably a 14-bolt. It will be MUCH stronger than your current axle (10 or 12-bolt). The front axle from the Suburban is probably a 10-bolt, but it will have slightly better brakes and heavier-duty components at the wheel ends. Properly running 40" tires isn't going to be cheap.
Your current trans (should be an SM465) has a very low first gear, which is helpful, but your truck will still be a dog with stock gears. If you go with a 5-speed, I would recommend an even lower ratio (5.13 or even 5.38) since you won't have as low of a first gear, and the overdrive will bring your RPM down to a reasonable number on the freeway. For reference, my S10 has the same transmission (SM465) with 37" tires, and I'm running 4.88 gears. I recommended 4.56 to you, even though you have bigger tires and a heavier vehicle, because your 454 has a lot more torque than my V-6.
The best low-end torque will generally come from a stock engine. Cams, etc. usually add torque at higher RPM. Not down low where you want it. Small-tube headers are an exception and can add low-end torque. This is even more important if you aren't planning on running low ring and pinion gears.
You'll need to measure the length after installing the lift and either have new shafts made from scratch, or have your current ones re-tubed with longer tubes.
That kit should work fine.
I would get this
and this
I had both of those on my K5
Offroad Design also makes some nice upper shackle hangers, but they're pretty expensive and probably not necessary. You might want their shackle kit, though, because the front shackles are a weak point.
Not a problem!
Old Apr 21, 2020 | 07:13 AM
What about axles ?
I have 1983 Suburban 8 lugs front & rear axles ( Pls. check photos )
Does it work with this project or shall I look for K30's axles ? I think it's DANA 60 front & 14 bolts rear
Which is much stronger than DANA 44 that comes in the Suburban 4WD
Somebody is advising that 40" tires can fit with major fender trim only
And it's recommended to replace axles. Is it correct ?
In this case I can go for 4" lift kit, with 8 lugs axles and customize drive shafts based on actual dimensions
Old May 8, 2020 | 11:55 PM
Hess13x's Avatar
I have 44" tires on my 82 k10 suburban with a 6" lift and major trimming. It still rubs offroad. I'll find a pic.
Old May 9, 2020 | 12:11 AM
Hess13x's Avatar
Before trimming.
What I had to cut.
So you can make 40s fit with 6" lift. I'm going to add a 3" body lift if I don't tear it down to use the drive train in my Jimmy or another project.
Metalslug137
Feb 1, 2016 12:58 PM
ACA1001
Tires and Wheels
Dec 11, 2015 04:45 PM
DesertStorm
Suspension Tech
Jan 19, 2015 09:23 PM
Blazerowner100
Tires and Wheels
30
Oct 21, 2013 04:52 AM
Bgray
Suspension Tech
Feb 17, 2006 12:21 AM
