4x4 HELP
Hi, new forum member here and I need some help.
I have a 98 Chevy Blazer LS 4x4 and the 4x4 is acting strange and I am completely miffed. It runs fine in 2wd, but when i press the 4x4 HI button (on the fly) to engage the 4x4 HI I do not think its engaging. I can hear a click behind the dash, the 4x4 HI button indicator switched from 2wd to 4x4 HI and it sounds like the front axel is trying to engage but the blazer doesn't drive or sound any different. The screwy part is 4x4 LOW is working just fine. It engages just fine when the the vehicle is stopped and in neutral, 4x4 LOW is engaged and then back to drive. Also, nothing lights up indicating the 4x4 function on the bezel/dash area. Any help would be great
My guess is you dont have vacuum getting to the actuator that engages the front axle. If the lights stay lit and dont flash then nothing is wrong with the TCCM i dont believe. Luckily vacuum is pretty easy to diagnose.
You say 4LO works but my guess is the front axle doesnt engage, it will still go into low gear tho. So put it in 4WD and get to some wet grass or something slippery hit the gas and see if the front tires spin. Or you can just put it in 4WD and try to turn SLOW on dry pavement and see if the inside front tire slips. Thats not good for the front end if it does engage tho.
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
