Suspension Tech Have a question about modifying your suspension? Ask it here.
98 4X4 sits a little low on right front
Old Oct 9, 2005 | 10:40 PM
tdannar's Avatar
tdannar is an unknown quantity at this point
Default 98 4X4 sits a little low on right front
I have not tried yet, but I hope I can adjust the right front torsion bar to raise the right front of the vehicle. It actually sits about 1" lower then the left front. Could be a rear spring, just thought I might try to adjust torsion bar. What think?
Terry
Old Oct 13, 2005 | 05:40 PM
Hanr3's Avatar
Default RE: 98 4X4 sits a little low on right front
How did it turn out?
Old Oct 18, 2005 | 02:39 AM
tdannar's Avatar
Leveled it right up. Took several more turns than I expected. Surprised that the torsion bar adjuster bold does not have a jam nut. I guess there is plenty of pressure on it and therefore, it won't back out on its own.
Old Oct 18, 2005 | 10:40 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
you might want to get the alignment checked out. whenever you adjust the torsion bars, it throws everything off.
Old Oct 27, 2005 | 03:24 PM
JRR_11's Avatar
JRR_11 is an unknown quantity at this point
I have heard that is like that straight from the factory, mine also sit about an inch lower on that side
2003ZR2
Sep 14, 2010 03:02 PM
dougg01
Jan 5, 2010 03:47 PM
chevyman45
Sep 14, 2009 11:42 PM
pfcmooney
Nov 5, 2007 08:28 PM
duckieboi
May 14, 2007 01:59 PM
