95 blazer 4wd indicator lights - Simple Question
Old Nov 19, 2008 | 04:13 PM
BIGGER_HAMMER's Avatar
BIGGER_HAMMER is an unknown quantity at this point
Default 95 blazer 4wd indicator lights - Simple Question
Hey All,
I have a New (well new to me) 1995 blazer.
I read the owners manual but it did not give a clear answer, so time to Go to the Pros!
I have a simple question about the four wheel drive system indicator lights.
I have the three button system (2 Hi, 4 High & 4 Low) When I push the "4 Hi" or "4 Low" switches, the pressed switch lights up and stay lit.
However when I go back to "2 Hi" there is no light. Should this switch be light or stay lit under normal driving?
If it is not lighting, is this an item that I can repair?
Thanks
BIGGER_HAMMER
Old Nov 19, 2008 | 07:26 PM
WolfPack's Avatar
Default RE: 95 blazer 4wd indicator lights - Simple Question
Yep it should stay lit. If the other two work, I'd say you just have a burnt out bulb/LED..cant recall which is in the 4wd switch.
Old Nov 21, 2008 | 02:00 PM
trouty31's Avatar
trouty31 is an unknown quantity at this point
I have the same thing going on with my "new to me" '95.
I figured that the 2 Hiwas supposed to be lit because at night, those buttons are too hard to see if they are all dark.
Is this a common bulb that can be picked up anywhere?
Marcin
Oct 27, 2013 08:02 AM
SL5417
Jan 23, 2013 12:43 PM
adaptechsolution
Apr 7, 2012 12:03 PM
mudsliner
Nov 26, 2006 12:56 AM
4WDBlaze
Engine & Internal
Oct 20, 2005 12:05 PM
