96 4x4
Old Nov 24, 2008 | 01:35 PM
Basic Gamer's Avatar
Basic Gamer is an unknown quantity at this point
Default 96 4x4
i have a 96 four door blazer and it runs fine just had the usual solenoid problems and bad fuel pump. but i have no 4x4 i can put the truck in 4lo and its all jerky like it should be but i have no wheel spin in the front at all. I took it to a local transmission shop and they checked the vacuum lines and said that they were fine. they also manually engaged the cable but the wheels still do not spin. so could there be a peice missing in the cv joints? maby a link or somthing...
Old Dec 5, 2008 | 04:35 PM
LS's Avatar
LS
LS is an unknown quantity at this point
Default RE: 96 4x4
In my dads 96 Blazer LS in 4WD, if the back wheels start slipping, the front wheels will pull it out.
Sorry for the bump
Old Dec 5, 2008 | 05:33 PM
Default RE: 96 4x4
If you pulled on the cable and it still did not lock in the front differential, then there is something wrong in the engagement mechanism in the axle itself. It is located in the passenger axle extension tube.
*Moving to Steering, Suspension, & Drivetrain*
Old Dec 11, 2008 | 10:36 AM
Default RE: 96 4x4
ok thanks im going to take it to a transmission shop cause i dont have any tools at home at the moment
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
