97 Bravada, advice on AWD Delete, already missing front drive shaft.
Old Sep 6, 2012 | 04:55 PM
You're making way too much work, and spending money needlessly.
Pull both half shafts out, remove both outer CV joints from the half shafts, install them back into the wheel hub assemblies and torque them down. Done! No need to drain the fluid, there's no driveshaft so the pinion shaft will not turn. The axles are essentially removed so the differential is not turning.
Old Sep 6, 2012 | 05:10 PM
Razmear's Avatar
Razmear is on a distinguished road
I need one new wheel hub regardless, and I can get 2 of the 2wd hubs for less than the cost of one of the awd hubs, so I'm actually saving a bit of cash.
The front diff is toast, no need to carry around an extra 75 pounds of useless metal, so it's coming out. It's already mostly out but as I only get one day a week off work and it started downpouring as I was working on the last bolt, it will be finally removed on my next day off (monday).
Old May 18, 2015 | 09:02 PM
packrat's Avatar
packrat is on a distinguished road
I have a 94 bravada with a bad front differential can I do the same thing with it take the drive shaft out and split the cv axles ? it just a beater only drivin 5 miles or so per day
Old May 18, 2015 | 09:30 PM
What transfer case do you have? If it's a 4472 Borg Warner, it won't work.
Post #11 is the cheapest, easiest way to do it. You need to put the outer CV's back in the hubs and torque the axle nuts or the bearing will fall apart.
Old Feb 10, 2018 | 01:06 PM
Wylie Melissa Bravek's Avatar
Wylie Melissa Bravek is on a distinguished road
Default But from hell
How did you get the nut off? Mine is very stuck!!
packrat
May 30, 2015 09:18 PM
Blade_24k
Feb 26, 2014 03:03 PM
street101
Oct 29, 2010 04:17 AM
drodr05
Sep 24, 2010 02:15 PM
lizzj70
Jun 23, 2010 06:57 PM
