97 Jimmy T bar bolts
Hi guys, I finally got the nasty bounce out of my front end. Unfortunatly I decided to have a shop do it for me. I brought my Jimmy into the shop and asked them to adjust it back to the factory ride height. They did and I noticed a huge difference on how the front end sat. It raised it almost 2 inches. Yes my T bars were that weak. I crawled under there to look and see how much they adjusted the bolts and the drivers side bolt is turned all the way in and the passengers side has about 2 threads showing.
Obviously I dont have any further adjustment left so what is my next option. Replace the tbars? Buy indexing keys? What would be the best option? Thanks for your help.
You could try your luck with a used set. There are different diameters (which relates to the spring rate) available. There should be a thread in the Lifting Tech section that details the part numbers, diameters, & weight ratings.
Kjared2
Oct 31, 2010 08:54 PM
95_4door
Nov 11, 2007 12:02 AM
88blackzcand95blazer
Mar 3, 2007 06:49 AM
