97ls 4x4 issue
Old Dec 21, 2007 | 10:31 AM
97lsblazer's Avatar
97lsblazer is an unknown quantity at this point
Default 97ls 4x4 issue
wonderful site guys, very informative. i have a 97 ls blazer 4x4 4door push button 4wd. t case is engaging, no vaccum leaks, i pulled the cable out 3/4 and clamped it, still no 4wd.. any ideas? thanks so much!
Old Dec 21, 2007 | 10:54 AM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: 97ls 4x4 issue
Its possible that the cable broke or has become disconnected from the front differential. Easiest way to check is to crawl under the front diff and on the passenger side you will see a cable running in to a tube with 3 bolts holding the tube to the diff. Remove the tube and slide it out a bit (you might leak a tiny bit of gear lube so keep a rag handy). You should see the cable attached to a hook with a little clip about the thickness of a paper clip holding it on. Make sure that is clipped in, if not then thats your issue. If its clipped then disconnect it and have someone move the other end in and out to make sure it moves like it should. If it doesnt you got a borked cable. If it does move then its inside the diff that you got an issue.
Hope that points ya in the right direction.
Old Dec 21, 2007 | 09:28 PM
97lsblazer's Avatar
ok, so the cable was a little gunky, i lubed it up, its working a lot better. its stil hard to pull out the full 1/2" to 3/4", but, i found that my vacuum line from the vacuum switch to the actuator has trans fluid in it, possible bad vacuum switch? thank for the help. very helpful, im much obliged
Old Dec 21, 2007 | 11:10 PM
Before you put it all back together with a new vacuum switch, pull out the fill plug on the back of the transfer case. It is possible that you have a leaking rear main seal on the transmission filling the transfer case up with trans fluid.
Old Dec 21, 2007 | 11:24 PM
97lsblazer's Avatar
thank for the advice, i was kinda thinking the same thing, after my tranny fluid was getting lower, but no leaks anywhere. i appreciate it guys.
Old Jan 2, 2008 | 09:59 PM
hurricanmitch's Avatar
hurricanmitch is an unknown quantity at this point
i Have the same problem any luck?
Old Jan 3, 2008 | 06:10 AM
Slightly different problem. Have you tried anything I suggested in your other thread???
brian79z
32
Feb 23, 2015 07:13 PM
99bblazer99
Jun 15, 2013 08:38 PM
1hugeblazer
Nov 14, 2011 02:46 AM
J.R. Clay
Mar 16, 2011 12:33 AM
extreme
Jan 5, 2010 07:29 AM
