Air ride suspension
Old Oct 29, 2023 | 12:29 PM
Lisag1960's Avatar
Lisag1960 is on a distinguished road
Default Air ride suspension
Bought 2000 GMC jimmy a few months ago really like unit but it rides really ruff. Ordered new shocks looked under truck found air bags on rear that seem to be maxed out tried to find info on air ride supp. On how to reset or if it has load level valve could find little info on system any help would be helpfull
Old Oct 29, 2023 | 01:47 PM
With the air bags, there are still.leaf springs too, correct? If so, perhaps the leaf springs need to be replaced so that the air bags don't have to do so much?
Old Oct 31, 2023 | 05:12 PM
El_Beautor's Avatar
Is it a factory air ride suspension, or an aftermarket add-on air shocks? You may have to do a RPO readout using your VIN to determine what was the original equipment.
If it's a factory air ride suspension, Christine is probably right that sagging leaf springs are causing the air levelling system to work harder giving a stiffer ride. It is also possible that the load level switch is broken or jammed, causing the air system to over-inflate the air shocks. I believe it's an arm that connects from the center of the axle to the body above the axle. Maybe check to see if the air system is functioning correctly, and shuts off when a certain height is achieved?
Old Nov 6, 2023 | 09:21 AM
Lisag1960's Avatar
Not very much info for me about problem on air ride had 1995 ranger there web sight was a lot better.
Old Nov 6, 2023 | 10:29 AM
Where did you look for information? Do you have a repair manual?
I have a 1999 service manual in which I could see what I find about this system.
For now here is a page that has an exploded parts diagram of the stock air ride suspension dated from 1998. Perhaps it could help in at least identifying what you have.
https:/nemigaparts.com/cat_spares/epc/chevrolet/54s-t/07/ts07-550/
Old Nov 16, 2023 | 11:38 AM
Lisag1960's Avatar
I am not computer person per last message does any one in the USA now any thing about my problem with air ride susp. Surely someone has worked at GMC or has seen problem before does any one know of better web sight ?
Old Nov 19, 2023 | 10:35 AM
Maybe if you could post a couple of pictures of your rear suspension, somebody here could tell you if it's from the factory or not. If it's an aftermarket add-on system, there might be a Shrader valve (tire-type valve) somewhere to adjust the air pressure.
dmac122
Sep 9, 2011 10:11 PM
Rockalot19822008
Mar 2, 2011 12:21 PM
Smoked
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Sep 10, 2010 08:34 AM
Black_04_Blazer
Oct 19, 2009 08:15 AM
mortalum620
Aug 15, 2006 10:44 AM
