Alignment question!?
Just had my alignment checked on my 95 4wd blazer 2 door. It was out of spec on my camber on both sides. Caster as well but my cam bolts are maxed out. I am -0.7 on the left and -1.0 on the right for camber. Specified range is -0.5 to 0.5. My question is what is the stock adjustment range of this cam bolt so i know which kit i need to order. Thanks
I would think that the inability of the shop to align your front end would be evidence that there is a part or parts that are broken or that your frame is bent. There are aftermarket ball joints and perhaps also adjusters that could help.
If you have your torsion keys cranked, then you'll have a problem with you chamber. Your best bet is to check them, lower if need be, or search into aftermarket solutions.
I cranked my torsion keys after I installed an add a leaf kit, needed because my rear end was sagging. Ended up maxing out my chamber adjustments and it still sat slanted. Ended up upgrading to a 2.5 lift kit by rough country.
Last edited by DonL; Dec 10, 2018 at 04:20 PM. Reason: Added more info not originally entered.
95blazerlt
Mar 8, 2014 05:40 PM
